Poor Download Speeds and Updates Not Installing
Message 1 of 14
Whenever I use the Autodesk Desktop Application or Download Manager to download or update a software like Maya, the download speeds are painfully slow, and the Autodesk Desktop App doesn't use my full internet speed for some reason. I have a 50Mbps connection, but in task manager, it shows the app uses only about 15Mbps.
The download speeds when downloading with the desktop app lingers around 300KBps to about 600KBps, whereas with browser download, I get about 4 MBps for the same package.
Also, after downloading an update after sitting for hours with the Desktop App, the update never installs and always gets stuck in midway. The Autodesk Desktop App is very useless and poor in my experience. Such a service is not expected from a company like Autodesk. Please fix this.
Replies (13)
Message 2 of 14
manu.gupta
Hi @Anonymous
Thanks for using Autodesk forum. Please accept our sincere apologies for the inconvenience you had while using ADA.
Can you try below steps:
        1. Exit Autodesk desktop app(from system tray menu)
        2. Stop AdAppMgr Service(task manager)
        3. Go to  -> %Programdata% > Autodesk > Delete the “SDS” folder
        4. Restart Autodesk desktop app and try to download and install the product.
Please find the attachment for log file instructions. Please send us the logs from the below locations so that we can investigate:
1.  %programdata%\Autodesk\sds\log
2. %localappdata%\Autodesk\.AdskAppManager
Manu
Message 3 of 14
manu.gupta
Hi @Anonymous
Just checking with you if the steps provided have solved your problem or it is still there?
If it is not solved, can you please send the log files for us to investigate?
Please mark "Accept Solution" if the solution provided has solved the issue,  so that others in the community can be benefited too.
Best Regards,
Manu
Message 4 of 14
I'm having the same issue, have done since the original download of all my autodesk programs. I tried deleting the SDS folder but it didn't fix it. My usual speeds are 60Mbps however autodesk never gets to 2Mbps. I don't have the log file in local appdata, and I have hidden files enabled. I hope the log file from the SDS folder will make do.
Emily
Message 5 of 14
manu.gupta
Hi  @Anonymous
May we know which version of ADA you are currently using on your machine. The latest version should be 7.0.10.89. Please check and download the latest version of ADA.
Let us know if you still face any issue while installing updates.
Best Regards,
Manu
Message 6 of 14
Yes it is the latest version as it was downloaded just 2 days ago
Message 7 of 14
pendean
Community Legend
Community Legend
Actually confirm the version number, you could have downloaded something else. post a screenshot of it.
Message 8 of 14
manu.gupta
Hi @Anonymous
Can you please send us screenshot showing the version which you have currently on your machine? We will check if it is latest version or not.
Manu
Message 9 of 14
dackermanY7Z7X
Observer
Observer
not OP but I have the same issue. My updates just say Waiting... forever. I am on the most recent version as well.
Edit: I followed the uninstall instructions from here: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Install-Autodesk-Desktop...
It seems to be installing now, but extremely slowly and failed the first time. I will update if it works.
Message 10 of 14
manu.gupta
Hi @dackermanY7Z7X
May we know if you are able to install or not. Please check the network speed too.
Manu
Message 11 of 14
I am having same issue.  have tried all of the above mentioned trouble shooting.
Message 12 of 14
Hi @Anonymous
Can you provide the screenshot of ADA version you are having installed on your machine. The latest version should be 7.0.12.84. If you do not have this version, please install it.
If you already have this latest version installed then please try below steps:
Please find the attachment for log file instructions. Provide the logs from the below locations so that we can investigate:
Manu
Message 13 of 14
Same problem updating AutoCAD 2019 and getting this message. When updating the app is waiting a long time with no movement on the progress bar. Any ideas, please?Capture 7.PNG
Message 14 of 14
I'm experiencing this same issue with every and any autodesk application - be it worksharing over VPN, downloading updates via Autodesk App, etc. All Adesk apps behave the exact same way. I have a confirmed 300-500mbps down speed 5G connection which is solid yet Revit and the updater will only ever max at around 10mbps.
Please dont respond with multiple requests for software versions etc. Everything is updated to latest as supplied by subscription. Please stop avoiding this glaring issue and resolve it as its clear every single user is affected and a singular troubleshoot of ADA versions is not the correct approach. Adesk Development team needs to get on to this right away as we are all increasingly working remotely.
