Is there a way to query if an Autodesk account has been setup on the local machine?
duanemizell
duanemizell
I'm designing a Powershell/WinForms script for employees that are new to our firm.
As you can see, I've programmed some logic to "DISABLE" certain buttons based off certain factors - like, have they already setup their Outlook profile?
I would like to enable this logic for my "AD" button, but I do not know a "good" way to query if the employee has already setup an Autodesk account or not. Is there any way to tell this from the local machine or any way to query this information? I assume not, but figured I would ask anyways!
Thanks!
DarrenP
I don’t believe so
You would have to check here: manage.autodesk.com
For the users
DarrenP
duanemizell
Thanks for the reply. I thought I may have been getting somewhere with the LoginState.xml file, but it doesn't seem to contain my email address for some reason.
I've been trying to locate this info (locally) so I don't have to authenticate for any remote queries - trying to keep the script as concise as possible.
My testing method is using my own email address to log in to Revit after trying to open it - my email address is unlicensed, so I am unable to proceed with opening Revit, but my email information appears to be stored somewhere because it's not prompting me anymore when I try to close and reopen Revit... Would be really nice to be able to glean this information somehow so I can enable or disable my button in my script.
duanemizell
Looks like there's a "WebServicesCache.xml" file located in:
<UsersAppData>\Local\Autodesk\Web Services\AdskLicensingAgent\34fafd89-a147-4142-b8bb-0c9ab116c63e
The file contains pretty much all the info I'm requesting and appears consistent across logins and PC's... Is there some reason I SHOULDN'T use this file to glean the info?
Try it & see
duanemizell
This function I wrote seems to work fine:
$emaildomain = "@<youremaildomain>.com"
Function Get-Autodesk-Login() {
	$ADeskConfFile = "$($env:LOCALAPPDATA)\Autodesk\Web Services\AdskLicensingAgent\34fafd89-a147-4142-b8bb-0c9ab116c63e\WebServicesCache.xml"
	$ADeskConfFile = Get-Content $ADeskConfFile
	$UsersUneditedEmail = $ADeskConfFile | Select-String -Pattern $emaildomain
	$UsersUneditedEmail = $UsersUneditedEmail -replace '[<]',''
	$UsersUneditedEmail = $UsersUneditedEmail -replace '[>]',''
	$UsersUneditedEmail = $UsersUneditedEmail -replace 'email',''
	$UsersUneditedEmail = $UsersUneditedEmail -replace '[/]',''
	$UsersEditedEmail = $UsersUneditedEmail -replace ' ',''
	If ($UsersEditedEmail -eq $null) {
		Return "$False"
	} ElseIf ($UsersEditedEmail -eq $UserEmail) {
		Return "$True"
	} Else {
		Return "$BROKEN"
