I see this application that can do everything that needs to be done in order to update software. Figures out what is installed. Figures out what patches it needs. Includes pre-requisite patches and handles the order of installation. That's awesome. Can I script this for administration purposes? If this was scriptable, I could cut out a ton of overhead to patch deployment.
Is there an admin tool that has the same functionality? The reason an endpoint application handling the updates is desired is because none of my CAD workers work out of an office so distributing patches through GPO/SCCM is problematic as the connection between headquarters and whatever hole they're in is not so great while they get better connections to Autodesk's infrastructure. Running scripts isn't an issue though.
