Hallo!👨🎓mein Name ist Rene!✋
Ich fertige Rennsportteile und Ersatzteile im Oldtimersegment.
Habe mich endgültig für Inventor/InventorCAM entschieden.
Ich konnte die 30 Tage Testversion erfolgreich für mich testen und kaufte mir jetzt eine Jahreslizenz.
Inventor ließ sich problemlos installieren.
Nur das HSMWorks Ultimate 2020 ist zwar installiert aber nicht im CAM zu sehen.
Habe noch Testversionprogramme mit CAD/CAM enthalten die ich zwar öffnen kann aber weder Werkzeugwege (Abzeilen, 3D-Bearbeitung) noch Simulation benutzen kann.
Warum ist HSMWorks Ultimate 2020 nicht in meinem Inventor?
Liebe grüße
Rene A.
Is the license you purchased just for Inventor, or for the Product Design and Manufacturing Collection?
HSMWorks is only included in the latter (and apparently also in a Fusion 360 subscription).
Can you see HSMWorks in your Autodesk account?
Does this help?: https://knowledge.autodesk.com/support/hsm/troubleshooting/caas/sfdcarticles/sfdcarticles/CAM-tab-is...
Or perhaps I have misunderstood your post, my German is quite rusty...
I`ve purchased the Product Designe and Manufacturing Collection.
Inclouding the HSMWorks Ultimate 2020 , Right?
I can see the HSM in my DesctopApp but not in Inventor "Add-In Manager"(Toolbar).
I tried to delete every file with your instructions.
1.Delete every file with HSM ..
2.Download HSMWorks Ultimate 2020 in my Downloadmanager.
3.Install.
4. Still not work 😄 … ._.
Please help me.
Need to do crazy stuff!
Rene A.
So when you open Inventor, is the CAM tab there or not?
If it is but running in trial, this might help... https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/While...
Otherwise I would maybe try and register it manually by running these two commands in Command Prompt (as administrator):
1)
The CAM Tab is there.
No it´s not a trial Version. no pop-up-window at start.
I tested your commands in cmd.exe.
Clipped some Attachments below.
I ran your first error message through Google Translate and got this:
"With your license you cannot generate any operations. These will be skipped."
What are you clicking on to get this error? Any of the CAM functions or a specific one?
I have never seen this error before so not sure what is happening. It might be best if you log a support case with Autodesk.
("With your license you cannot generate any operations. These will be skipped."
What are you clicking on to get this error? Any of the CAM functions or a specific one?)
I wanted to simulate a 3D-adaptive Clearing strategy from an older CAD/CAM that i programmed last month.
This ERROR cums when i want to generate the toolpath without HSMWorks Ultimate2020 in this oparation.
Cant set the HSMWorks Ultimate 2020 in my Inventor. Deleted every Programm. Installed every Thing i want to use.
But still not working...
mhhh.
I tried to delete hsmworks.
"hsmworks.dll cant found"
could u pls help me?
some pics as attachments.
is this the Problem?
Sorry I don't understand what you were doing... I don't work with Inventor/CAM myself.
But based on what I found online:
HSMWorks = works with SolidWorks
CAM Ultimate = works with Inventor
Not sure if when you're installing it decides which one gets installed based on what base program you have.
Why are you deleting things? It looks like you deleted a .dll that was used by the program...
If you have the time it's probably worth conducting a Clean Uninstall together with using the Microsoft Uninstall Tool and then redownloading via Browser Download, follow best practices for installation...
If nothing works contact Autodesk support.
