downloads
downloads
downloads
can we download autocad from Autodesk desktop app? because I tried downloading the autocad and the instalization was done but I couldn't find the autocad app , instead I was left with Autodesk app on my desktop .
leowarren34
The autodesk app is best left ignored in most cases;
All downloads and updates can be found in: http://manage.autodesk.com/
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
srinivasarao.potla
ation Hi@ srirlamounika,
Thanks for your feedback.
Yes, you can install Autocad from autodesk desktop app.
Did you signed in Autodesk desktop app?
are you trying to install the Autocad from Autodesk desktop app?
if you are trying to install from autodesk desktop app, just open autodesk desktop app, it will show the installation  progress..
Hope this helps?
Srinivas.
pendean
Community Legend
Community Legend
Looks like you have an incomplete install: this method works for all of us all the time https://knowledge.autodesk.com/customer-service/download-install/download/about-download-methods/bro...
JohnAhern3735
Observer
Observer
Srinivas, I am logged in (connected) and the Notifications still says "You have 1 product to update."
I've already updated all the products, twice, and it still says the same thing.
The strange thing was it had the Revit 2020.0.1 Hotfix. It did not have the 2020.0.2 showing, nor the 2020.0.2 Hotfix.
SO the REAL question is WHY?? Do I have to find the 2020.0.2 + Hotfix somewhere in the Autodesk Cloud??
Also, how do I make a "Screencast"??
DarrenP
revit 2020.2.1 is the latest update which you can get from the desktop app or your autodesk account
DarrenP
srinivasarao.potla
Hi@JohnAhern3735,
Thanks for your reply.
Autodesk desktop app will display all the products for your contract. if you installed the product then it will display as installed or launch. Regarding updates, it will display only available updates. if you installed any update from accounts portal then autodesk desktop app won't display.
you mentioned that Autodesk desktop app showing one notification says that you need to update the product, may i know the product?
Regarding Revit updates, the right now available update is Revit 2020.2.1 Hotfix. so if you install Revit 2020.2.1 Hotfix from accounts portal, it wont display on autodesk desktop app, if not, it will display.
Hope this helps.
Srinivas.
