Afternoon All
I am running Autocad 2023 & Inventor 2023
The desktop app is listing updates available for my products, when i click them it goes through the process only to report that this update is already installed ?
Is this because we where late installing 2023, and the version i have installed had the updates already bundled in them ?
The updates disappear from the list afterwards
Any idea's as this is frustrating to say the least
Steve
Solved by lancermandc_co_za. Go to Solution.
Solved by pendean. Go to Solution.
I have the same issue, only they don't clear. They stay on my suggested updates page(s) forever, making difficult to sort thru the valid ones and the bogus ones. Is there a way to CLEAR the updates displayed on the Desktop App, to start fresh?
i've been having the same issue. Autodesk's tech support is pretty useless, their typical response is uninstall and start fresh which didn't work. Would it be that hard to add a "hide this update" button?
Thank you,
I will just ignore it then.
Un installing as not an easy option as i have to then go to the IT dept. and explain why i want it removed and this is more trouble than ignoring notifications.
Steve
@lancermandc_co_za wrote:
Not really a solution, is it?
If there was one it would be posted. So... what do you think ought to be done by us end users suffering with it?
Hint: stop using it, so their metrics on it drop, then they decide to fix it or just abandon it. And we get the relief we need.
I have this issues as well on my computer, but I have noticed that other co worker computers show the updates correctly and the computers have the same setup. So Very Strange.
When I clicked on the thread, it said there was a solution, which I clicked on. Hense my frustration when I found out that the post was in fact not a solution at all......
Maybe compare computer operating specs or maybe more importantly, anti-virus and firewall settings, DNS gateways or even Domain policies (if not on a workgroup environment).
Same issue, and the collection of updates I have already updated keeps growing and growing. On top of this, we only use/install regular AutoCAD, Map 3D, and Civil 3D from the AEC Suite, yet I keep getting update notifications for seemingly unrelated parts of the Suite I do not even use (like Vehicle Tracking and Fabrication CADmep). This app used to work much better than this, so I am not sure what was screwed up in an update. At least the updates still say how long ago updates were released. I can then ignore the plethora of updates to no longer go through the effort to download GB+ files to try install that will then only tell me I already have them installed. This is bad enough, but then they momentarily are removed the list, then return after a refresh. Very frustrating Autodesk!
i just ignore it now and then let IT update when they do there rounds, they can sort it
Same issues here, and I am also the IT for updates and patches; so multiple the frustration by the number of users...and it makes for a long day. Should be a simple fix for Autodesk, yet here we are. The end results is they release HOT FIXES, but frustrated users expect the desktop app to just be broken, so they ignore actual real patches that may be needed.
