I'm having trouble with desktop app, it doesn't show any update to my products. I'm using windows 10 64x and my anti-virus is Kaspersky.
I get updates showing up on one computer but not others. I have floating licenses. I would like to have the same version of Maya on all. I've downloaded the Autodesk_Maya_2017_Update4_x64.exe from the one computer that shows the SP4 update on its Autodesk desktop app but when I try using that to update the other computer it fails. Any Suggestions?
hi,
thanks for your feedback. can you share a screencapture with us?
Also could you login to Autodesk Account to see if you could see any updates for any of these product.
Some updates are tied to your contract, if you could see them at Autodesk account, and if you installed using the same Serial number, you should see them in the desktop app.
if not, could you sent us your log file(see file attached below), so that we could look into this ?
Thanks!
I had a similar problem when i reinstalled my pc 4 - 5 months back.
I tried to reinstall the desktop app but got problems with the licensing service app.
Unfortunately I had to reinstall my pc again to solve the matter.
Have you tried to reinstall the desktop app?
Hello@1161314
Thanks for your feedback.
You are seeing updates on ADA and others not, that means please check that if contract manager may applied any filter for other users.
Please try this
Still you have problem, please try this,
Please send me (srinivasarao.potla@autodesk.com)the log files form the machine for which you are not seeing updates, i will investigate and get back to you.
Please find the attachment for log file instructions.
Srinivas
Did you solve your problem?My desktop app has been loading,,,as picture
hi @Anonymous
Since when your app is becoming like this?
can you try the steps below:
if it doesn't work, could you please share your log by doing the following instruction attached.
Hello@胡长林,
It is may be due to up-gradation of older version to newer version.
Please try this
Please try this
Please send me the log files (srinivasarao.potla@autodesk.com), i will do further investigation.
Srinivas
Hello@胡长林,
Please try this
Please try this
Srinivas
