ADA is designed to update itself whenever a new version becomes available. If you observe that the ADA you have installed has not been updated yet, do the following. You can find the version on the 'About' box of ADA.
#1 Check ADA self-update option -
- Open the 'Settings' window (drop-down options of the 'Sign-in' control)
- Ensure that the 'Autodesk Desktop App updates' option is 'checked'
- If it's unchecked, check the option, close the settings window, and may use the 'Check Now' option of the ADA system tray icon.
#2 ADA self-update option was selected but not updating -
- Right-click on Autodesk Desktop App system tray menu and click 'Exit'
- Open Task Manager > Service tab, right-click on AdAppMgrSvc and select Stop
- Browse to %programdata%\Autodesk\ and Delete the SDS folder
- Launch Autodesk Desktop App
#3 The latest version can be installed using this link, https://www.autodesk.com/desktop-app
We thank you all for your feedback via this and other forums. They are highly valuable to us as they help us improve this software.
