Autodesk Desktop App (Read-Only)
Welcome to the Autodesk Desktop App Forum. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Autodesk Desktop App and updates
4 REPLIES 4
MarcinStJasinski
1594 Views, 4 Replies
Hello.
My Autodesk Desktop application says I have an update to Inventor 2017. Currently I only have Inventor Pro 2021. The problem started repeating with Inventor 2019. I uninstalled all versions prior to 2021. What can I do more? Thanks.
Tags (1)
4 REPLIES 4
pendean
in reply to: MarcinStJasinski
Read this https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-Desktop-App-sho...
or better yet, uninstall that app altogether: updates are not frequent in a year and you can grab then from your Autodesk Account page.
HTH
hi @MarcinStJasinski
Thanks for your feedback.
Could you please check the registry(Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\UPI2\), is there any UPI2 values related to Inventor 2017 and 2019? if you have, please delete those UPI2 values.
click each UPI2 value in the left side pane and check the GUID value and version in right pane, if you see any GUID values related to 2017 and 2019. delete the GUID values. after deleting the values, please follow the below steps
Exit Autodesk desktop app(from system tray menu)
Stop AdAppMgr Service(task manager)
%Programdata% > Autodesk > Delete the “SDS” folder
Restart Autodesk desktop app.
Here is example.
Hope this helps.
Srinivas.
MarcinStJasinski
in reply to: pendean
Thank you buddy.
Thank you buddy, too.
SOLVED. It worked.
