3DS Max 2018 update error
hello!
I'm looking for some help to update my 3DS Max 2018.
So, I downloaded my Max 2018 today morning.
However, I'm having difficulty of install update 4 on my 3DS Max 2018.
Autodesk Desktop gave me this error:
  Another version of this product is already installed. installation of this version cannot continue. To configure or remove the existing version of this product.
So, I uninstalled my 3DS Max and reinstall again, got same error.
Here is the error log I'm having.
[0990:5DE4][2020-03-25T12:07:30]i001: Burn v3.10.2.2516, Windows v10.0 (Build 18362: Service Pack 0), path: C:\Users\furye\AppData\Local\Temp\{F0E62938-A0FC-4992-9810-C4362810FCCA}\.cr\3dsMax2018.4_Update.exe
[0990:5DE4][2020-03-25T12:07:30]i000: Initializing numeric variable 'PRODUCT_INSTALLED' to value '1'
[0990:5DE4][2020-03-25T12:07:30]i000: Initializing string variable 'PRODUCT_GUID' to value '{52B37EC7-D836-0410-0764-3C24BCED2010}'
[0990:5DE4][2020-03-25T12:07:30]i000: Initializing string variable 'OPTOUT_KB2918614' to value 'NO'
[0990:5DE4][2020-03-25T12:07:30]i000: Initializing string variable 'AdskBundleTitle' to value '[WixBundleName]'
[0990:5DE4][2020-03-25T12:07:30]i009: Command Line: '-burn.clean.room=C:\Users\furye\Downloads\DCC04DFE-E7BD-4C22-986A-7CD4BD1B8F85\3dsMax2018.4_Update.exe'
[0990:5DE4][2020-03-25T12:07:30]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\furye\Downloads\DCC04DFE-E7BD-4C22-986A-7CD4BD1B8F85\3dsMax2018.4_Update.exe'
[0990:5DE4][2020-03-25T12:07:30]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\furye\Downloads\DCC04DFE-E7BD-4C22-986A-7CD4BD1B8F85\'
[0990:5DE4][2020-03-25T12:07:31]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\furye\AppData\Local\Temp\Autodesk_3ds_Max_2018.4_Update.Setup_20200325120731.log'
[0990:5DE4][2020-03-25T12:07:31]i000: Setting string variable 'WixBundleName' to value 'Autodesk 3ds Max 2018.4 Update'
[0990:5DE4][2020-03-25T12:07:31]i000: Setting string variable 'WixBundleManufacturer' to value 'Autodesk'
[0990:2374][2020-03-25T12:07:31]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[0990:2374][2020-03-25T12:07:31]i000: There is a Beta version of this update already installed. Please remove the Beta version and try this installation again.
[0990:2374][2020-03-25T12:07:31]i000: 1
[0990:2374][2020-03-25T12:07:31]i000: Setting version variable 'WixBundleFileVersion' to value '20.4.0.0'
[0990:2374][2020-03-25T12:07:31]i000: Running detect BA function
[0990:2374][2020-03-25T12:07:31]i000: >>> Running OnDetect function
[0990:2374][2020-03-25T12:07:31]i000: Setting numeric variable 'PRODUCT_INSTALLED' to value 0
[0990:2374][2020-03-25T12:07:31]i000: >>> Successfully located target product installation
[0990:2374][2020-03-25T12:07:31]i000: OPTOUT_KB2918614== NO
[0990:5DE4][2020-03-25T12:07:32]i100: Detect begin, 2 packages
[0990:5DE4][2020-03-25T12:07:32]i000: Trying per-machine extended info for property 'State' for product: {52B37EC7-D836-0410-0764-3C24BCED2010}
[0990:5DE4][2020-03-25T12:07:32]i000: Setting numeric variable 'TargetProductInstalled' to value 5
[0990:5DE4][2020-03-25T12:07:32]i000: Setting version variable 'InstalledVersion' to value '20.0.0.966'
[0990:5DE4][2020-03-25T12:07:32]i107: Detected forward compatible bundle: {396596ec-aaa1-4fb6-a20d-08ba4bee913d}, type: Upgrade, scope: PerMachine, version: 20.4.8.0, enabled: No
[0990:5DE4][2020-03-25T12:07:32]i102: Detected related bundle: {396596ec-aaa1-4fb6-a20d-08ba4bee913d}, type: Upgrade, scope: PerMachine, version: 20.4.8.0, operation: Downgrade
[0990:5DE4][2020-03-25T12:07:32]i106: Calculating patch applicability for target product code: {52B37EC7-D836-0410-0764-3C24BCED2010}, context: Machine
[0990:5DE4][2020-03-25T12:07:32]i103: Detected related package: {471069C7-09E2-4289-8EB7-852237FD867E}, scope: PerMachine, version: 1.0.712.0, language: 0 operation: MajorUpgrade
[0990:5DE4][2020-03-25T12:07:32]i101: Detected package: Max2018Update4, state: Absent, cached: None
[0990:5DE4][2020-03-25T12:07:32]i105: Detected package: Max2018Update4 target: {52B37EC7-D836-0410-0764-3C24BCED2010}, state: Absent
[0990:5DE4][2020-03-25T12:07:32]i101: Detected package: ArnoldPlug, state: Absent, cached: None
[0990:5DE4][2020-03-25T12:07:32]i000: Running detect complete BA function
[0990:5DE4][2020-03-25T12:07:32]i000: Running OnDetectComplete
[0990:5DE4][2020-03-25T12:07:32]i052: Condition '0=0 OR VersionNT64' evaluates to true.
[0990:5DE4][2020-03-25T12:07:32]i052: Condition '1=0 OR WixBundleInstalled OR TargetProductInstalled =5' evaluates to true.
[0990:5DE4][2020-03-25T12:07:32]i052: Condition '0=0 OR InstalledVersion <= "20.4.0.0"' evaluates to true.
[0990:5DE4][2020-03-25T12:07:32]i199: Detect complete, result: 0x0
[0990:2374][2020-03-25T12:07:32]e000: Error 0x80070666: Cannot install a product when a newer version is installed.
[0990:2374][2020-03-25T12:07:32]e000: 0x80070666 - Another version of this product is already installed. Installation of this version cannot continue. To configure or remove the existing version of this product, use Add/Remove Programs on the Control Panel.
DarrenP
did you check to see if that update was already installed?
DarrenP
