Autodesk Community Tips - AutoCAD Products
Autodesk Community Tips are bite-sized fixes, shortcuts, advice, and how-to tips shared by Community members.
Use shift key in AutoCAD for increased productivity - Part 1
Contributed by:
The SHIFT key is a significant tool that can assist users in enhancing their productivity in AutoCAD. Here, we'll look at some quick hints for using AutoCAD's SHIFT key to speed up your drafting process.
Tip-1
For the Snap Override menu and other context-sensitive screen menus, Shift-right click.
The context menu for snap overrides will appear when pressing this shortcut key combination. While using AutoCAD for design, always use this.
E.g., Draw a line, and then while holding down the Shift-right click, the OSNAP menu will appear for use.
Comments
@BhaskarMurari , Shift + right-click is something I use ALL the time. I keep only the endpoint and node selected and shift + right-click everything else.
Thanks bud!
You can select "endpoint" by typing "e" ans then SPACEBAR instead of mousing over and clicking. šŸ™‚
Constantly use this to use "mid between 2 points" one of my favorite snaps!
äø€ę™‚ēš„恫ORTHOMODE(F8)恫å‡ŗę„ć‚‹ć®ć§ē¢ŗ恋恫ä¾æåˆ©ć§ć™ć€‚
ćŖ恊态ORTHOMODE(F8)悈悊POLAR TRACKING(F10)悒åøø恫ONć«ć—ćŸę–¹ćŒåŠ¹ęžœēš„恠ćØę€ć„ć¾ć™ć€‚
ć“ć®ć‚¢ćƒ—ćƒ­ćƒ¼ćƒćÆ态ORTHOMODE (F8) 恌č‡Ŗē”±åŗ¦ć‚’äø‹ć’ć‚‹ćØć„ć†č€ƒćˆć«åŸŗć„ć„ć¦ć„ć¾ć™ć€‚ POLAR TRACKING(F10) 悂ēœŸć£ē›“恐恙恐ćŖē·šć‚’å¼•ć‘ć¾ć™ć€‚
