Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
142 Views, 5 Replies
Read Only
We are getting alot of read-only problems. The drawing is not open or
read-only but adt3 thinks it is for some reason.
Chris Olson
5 REPLIES 5
One simple thing to check. Under preferences / open and save tab / is your
demand load xrefs set to enabled with copy?
-Beau Turner
Chris Olson wrote in message
news:C018ABF87F8FD14A5DB9ECF26F5EE191@in.WebX.maYIadrTaRb...
> Thanks,
> Chris Olson
There have been a number of reports of this problem and I first saw this
back when I started using ADT2 almost two years ago. There was a post in the
past week or so that seemed the most logical to me that said something to
the effect that on a Network (any) Autocad had to wait longer than it's
program time to check the status of a drawing so it would assume some else
had the drawing. Therefore it is changed to Read-Only. People reporting
this problem have been using Win98, NT4 and any number Network software.
There does not seem to be any common cause except it happens. I've seen it
happen to me for days in a row, 5-6 times a day then not happen for months.
Have Fun,
Ron
"Chris Olson" wrote in message
> Thanks,
> Chris Olson
Is "enable with copy" checked in your options window?
> Thanks,
> Chris Olson
Yes enable with a copy is checked.
"James Clarke" wrote in message
news:A9444FB11079CE222B3D6F37E0EF1FCA@in.WebX.maYIadrTaRb...
> > Thanks,
> > Chris Olson
The problems I've had have been with drawing w/o xref's so do not think that
is the problem.
"Beau Turner" wrote in message
news:01B3086847C33C444D5250A9217911B3@in.WebX.maYIadrTaRb...
your
> -Beau Turner
> > Thanks,
> > Chris Olson
