Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
262 Views, 5 Replies
muntins
Can you have unequal muntin spacing in windows?
Carolyn
5 REPLIES 5
Yes, however it will require a custom block to do this. The default muntin
generator currently cannot do this for you.
Carolyn Gibbs wrote in message
news:f06871f.-1@WebX.maYIadrTaRb...
> Thanks
> Carolyn
Thanks John. I'm trying ti use Window assemblies instead.
"John Herridge" wrote in message
news:375851E90E768105D12D44BD062F6311@in.WebX.maYIadrTaRb...
muntin
> > Thanks
> > Carolyn
Hi Carolyn,
Not by using Muntin tools. You can create a custom block & attach it to your
window style.
If your doing alot of this, you might consider using one of the window
manufacturers (Pella, Marvin, Anderson) products to generate the geometry.
Hope that helps,
Dennis McNeal
Autodesk Building Industry Division
"Carolyn Gibbs" wrote in message
> Thanks
> Carolyn
Hi Carolyn,
If your making a Window Assembly use grids for mullions. If you need
detailed muntins, I'd go with window/custom block as Assembly infill.
Is that what you need?
Dennis McNeal
news:302F6C154E44D111BAF8953D05929243@in.WebX.maYIadrTaRb...
> muntin
> > > Thanks
> > > Carolyn
Yes, I've been using grids for mullions. Its working out fine for now. I'm
not sure how much detail I'll need later.
Thanks again
Carolyn
"Dennis McNeal - Autodesk" wrote in message
news:7121D9D3AD0C1510FBE7675AC6481222@in.WebX.maYIadrTaRb...
> Hi Carolyn,
> Dennis McNeal
> > muntin
> > > > Thanks
> > > > Carolyn
