Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Mass Element Edits
3 REPLIES 3
156 Views, 3 Replies
Mass Element Edits
Okay I am a student, and I am having trouble with mass element commands. When I work on the program at school all the commands for mass elements work fine, but my student version at home is giving me troubles. When I right click on polylines to convert them to mass elements I don't get the optional commands on the menu so I have to type in the command. But I have also found that once I have started working with a mass element and I right click it to divide, I once again do not get any optional commands in the menu, (specifically I am wanting the split face command) and when I search the help menu the only way to do it that the help menu lists is to right click and choose the command. Do I not have something setup right in my home version? This seems to happen for several commands that I have had to resort to learning and typing in. Thanks in advance for your help. - Darsey
3 REPLIES 3
Same version at home and at school of ADT?
Reid M. Addis
Registered Architect
Architectural Applications Specialist
Granary Associates
411 North 20th Street
Philadelphia, PA 19130
Ph. 215-665-7056
email: addis@granaryassoc.com
Also, is "Noun/Verb Selection" turned on the Options dialog box?
Larry Bettes
ADT, LDT/CD & C3D
(all 2006 with all SPs installed)
P4 - Dual 3.0 GHz, 1.00 GB RAM
RADEON 9550 AGP - 256 MB
Windows XP Pro, SP 2
"Reid M. Addis" wrote in message
news:4948329@discussion.autodesk.com...
Reid M. Addis
Granary Associates
Ph. 215-665-7056
Yes, it is the same version but I am not sure about the "noun/verb selection" and will have to check it out. Thanks again. - Darsey
Technology Administrators
