🔊 Autodesk Access - Working with Deployments - FAQ (Please Read)
handjonathan
Autodesk Autodesk
Message 1 of 1
handjonathan
How do I install Access via SCCM/Intune?
Starting March 15th, download Access from the product page, and create an SCCM/Intune package with it as you usually would. To install Autodesk Access silently, use the following parameter:  AdODIS-Installer.exe --unattendedmodeui
How do I update existing deployment packages that may or may not have had ADA to include Access?
We recommend installing Access prior to running these deployment installations so that ADA is skipped, and Access is installed.  For SCCM/Intune, add Access as a new task prior to the deployment installation.  Starting March 15th, download Access from the product page, and create an SCCM/Intune package with it as you usually would.
Jonathan Hand
Technical Marketing Manager | Construction
Replies (0)
