Autodesk Access Popup on Citrix VDA sign in
lharveyNWUPE
Observer Observer
Message 1 of 15
lharveyNWUPE
Observer
Observer
Hi, we're having several users encountering an issue where Autodesk Access will open continuously on a user's session, it appears to be triggered when subsequent users log into the VDA.
Users started reporting this on 17/03/2023 and the issue is still occurring.
Version of Autodesk Access installed is Version 1.39.0.174
It is installed on a Server 2019 Datacenter VDA running in Citrix Cloud.
Any suggestions on what we can do to prevent this from happening?
Thanks for the help!
Replies (14)
Message 2 of 15
danny.polkinhorn
Autodesk Support
Autodesk Support
Hi Liam, can you create a support case, and send me the case number here please?
Danny Polkinhorn
Sr. Product Manager
Message 3 of 15
lharveyNWUPE
Observer
Observer
Hi Danny, thanks for the reply. I tried initially to create a support case however we don't have support included in our license. I was prompted to post here.
Message 4 of 15
shevaun_mack
Observer
Observer
We are having the same problem with Autodesk Access Version 1.40.0.24 in Citrix.
Message 5 of 15
Simon_Weel
Jus uninstall AA?
Message 6 of 15
Gizzmallach
Community Visitor
Community Visitor
Same issues here..
would be nice if there was an GPO to disable this for users
Message 7 of 15
shevaun_mack
Observer
Observer
It doesn't appear as a separate product in control panel/add remove programs, or through Settings.  I tried the uninstall option on the start menu but it doesn't seem to have done anything.
Message 8 of 15
jjmartin333
Community Visitor
Community Visitor
Having this same issue, but in the MS RDS environment.
Message 9 of 15
Simon_Weel
Sneaky! It doesn't even turn up in Bulk Crap Uninstaller, so it must be part of another installer. I notice there's a service 'Autodesk Access Service Host' and I disabled it - doesn't seem to affect the applications. But I don't know if that will stop AA from popping up...
Edit: was going through the folder C:\Program Files\Autodesk\AdODIS\V1\Setup and in the script folder there's an uninstaller for the service.
Message 10 of 15
jsbA34M5
Observer
Observer
Same problem under Citrix VDA and 300 users.
Do you think there will be a solution very soon?
Message 11 of 15
Simon_Weel
There is a registry setting to disable users from installing updates. How to disable users ability to install updates via Autodesk Access
With this setting, I haven't seen the Autodesk Access window on any machine?
Message 12 of 15
jsbA34M5
Observer
Observer
Under Citrix VDA, the operation is obviously not the same. The registry solution does not work.
Message 13 of 15
Simon_Weel
I don't have experience with Citrix - does it generate a Windows User profile 'on the fly'? If that's the case, then you might be able to inject the registry setting. Maybe Citrix can run additional programs when Windows sets up the desktop. Like I have this registry setting pushed out by the Windows Login script, which runs in the User context.
Message 14 of 15
jsbA34M5
Observer
Observer
Yes, registry keys can be pushed during user login. But I couldn't find which keys to modify
the only one I found didn't work
Message 15 of 15
jsbA34M5
Observer
Observer
I couldn't find any info...seriously what is this crazy thing?
