Hola. Mi problema es con la reinstalacion del autocad.
compre una pc nueva con windows 10 y le logre instalar el autocad arquitectura 2017, lo termine eliminando porque solo me interesaba el autocad normal pero cuando trate de instalarlo me sale el mensaje de descarga fallida. he tratado de instalarlo tanto en las versions 2014 hasta la 1017 y nada.
simplemente me indica que los productos no han podido ser instalados y el siguien mensaje
ayuda por favor
2016/11/29:16:03:09 liza3 LAPTOP-8KN10TAC === Setup started on LAPTOP-8KN10TAC by liza3 ===
2016/11/29:16:03:09 liza3 LAPTOP-8KN10TAC Path_Length: 154
2016/11/29:16:03:09 liza3 LAPTOP-8KN10TAC Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/11/29:16:03:09 liza3 LAPTOP-8KN10TAC Launch
2016/11/29:16:03:09 liza3 LAPTOP-8KN10TAC CommandLine /PK 001H1 /SN 900-62814630 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/11/29:16:03:09 liza3 LAPTOP-8KN10TAC Current Directory C:\Users\liza3\AppData\Local\Temp\_AI36DE.tmp
2016/11/29:16:03:14 liza3 LAPTOP-8KN10TAC === Setup ended ===
2016/11/29:16:03:10 liza3 LAPTOP-8KN10TAC === Setup started on LAPTOP-8KN10TAC by liza3 ===
2016/11/29:16:03:10 liza3 LAPTOP-8KN10TAC Path_Length: 154
2016/11/29:16:03:10 liza3 LAPTOP-8KN10TAC Current Directory C:\Users\liza3\AppData\Local\Temp\_AI36DE.tmp
2016/11/29:16:03:10 liza3 LAPTOP-8KN10TAC Launch
2016/11/29:16:03:10 liza3 LAPTOP-8KN10TAC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/11/29:16:03:10 liza3 LAPTOP-8KN10TAC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/11/29:16:03:11 liza3 LAPTOP-8KN10TAC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\liza3\AppData\Local\Temp\_AI36DE.tmp\Setup\AcSetup.dll
2016/11/29:16:03:11 liza3 LAPTOP-8KN10TAC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/29:16:03:11 liza3 LAPTOP-8KN10TAC PageOpen LaunchDialog
2016/11/29:16:04:08 liza3 LAPTOP-8KN10TAC PageOpen LicenseDialog
2016/11/29:16:04:08 liza3 LAPTOP-8KN10TAC PageOpen ProductInfoDialog
2016/11/29:16:04:08 liza3 LAPTOP-8KN10TAC PageOpen ProductSelectionDialog2
2016/11/29:16:04:50 liza3 LAPTOP-8KN10TAC PageOpen FullProgressDialog
2016/11/29:16:04:51 liza3 LAPTOP-8KN10TAC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/11/29:16:04:51 liza3 LAPTOP-8KN10TAC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/11/29:16:04:51 liza3 LAPTOP-8KN10TAC Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/11/29:16:04:51 liza3 LAPTOP-8KN10TAC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/29:16:05:12 liza3 LAPTOP-8KN10TAC Install DirectX Runtime Succeeded
2016/11/29:16:05:12 liza3 LAPTOP-8KN10TAC Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/11/29:16:07:22 liza3 LAPTOP-8KN10TAC Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/11/29:16:07:22 liza3 LAPTOP-8KN10TAC Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/11/29:16:07:22 liza3 LAPTOP-8KN10TAC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Estimado compañero descarga el instalador a tu pc y luego instalalo offline si gustas es decir sin conexion a internet, el problema es que tu estas instalando directamente desde el internet y una interrupción en la descarga de los instaladores cancela todo, hace poco resolví un caso parecido con windows 10, al parecer el error es crónico si es que se instala desde la nube. sigue las indicaciones y desactiva el antivirus porque bloquea ventanas emergentes o instalaciones automáticas.
saludos...
Miguel Angel Aguilar Plasencia
Ing. Civil-Especialista en Vías-Topografía & Geodesia
Instructor ATC Macrotec Training Center
Especialista en MVCS-PNSU
Facebook | Youtube | Screencast | LinkedIn
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
