ERROR 69009688 DE INSTALACIÓN AUTOCAD LT 2023
dcastilloBUW5U
Observer
Observer
dcastilloBUW5U
Observer
Observer
La descarga llega al 38% y se congela.
0 Me gusta
Responder
Soluciones aceptadas (2)
645 Vistas
2 Respuestas
Respuestas (2)
elmer.munoz
Solución aceptada
Hola @dcastilloBUW5U
¡Bienvenido a la comunidad Autodesk!
Verifica las características del sistema.
System requirements for AutoCAD LT 2023 (Windows)
Operating SystemMicrosoft® Windows® 11 or Windows 10 version 1809 or above. See Autodesk's Product Support Lifecycle for support information.
ProcessorBasic: 2.5–2.9 GHz processor (base) ARM Processors are not supported.
Recommended: 3+ GHz processor (base), 4+ GHz (turbo)
MemoryBasic: 8 GB
Recommended: 16 GB
Display ResolutionConventional Displays:
1920 x 1080 with True Color
High Resolution & 4K Displays:
Resolutions up to 3840 x 2160 (with capable display card)
Display Card
Basic: 1 GB GPU with 29 GB/s Bandwidth and DirectX 11 compliant
Recommended: 4 GB GPU with 106 GB/s Bandwidth and DirectX 12 compliant
DirectX 12 with Feature Level 12_0 is required for Shaded(Fast) and Shaded with edges(Fast) visual styles.
Disk Space10.0 GB (suggested SSD)
Pointing DeviceMS-Mouse compliant
.NET Framework.NET Framework Version 4.8 or later
System requirements for AutoCAD LT 2023 for Mac
Operating SystemApple® macOS® Monterey v12
Apple® macOS® Big Sur v11
Apple® macOS® Catalina v10.15
ModelBasic: Apple Mac Pro® 4.1, MacBook Pro® 5.1, iMac® 8.1, Mac mini® 3.1, MacBook Air®, MacBook® 5.1
Recommended: Apple Mac® models supporting Metal Graphics Engine
Apple Mac models with M series chip are supported under Rosetta 2 mode.
CPU Type64-bit Intel CPU
Apple M series CPU
MemoryBasic: 4GB
Recommended: 8GB or higher
Display ResolutionBasic: 1280 x 800 display
High Resolution: 2880 x 1800 with Retina Display
Disk Space5 GB free disk space for download and installation
Pointing DeviceApple-compliant Mouse, Apple-compliant Trackpad, Microsoft-compliant mouse
Display CardRecommended: Mac native installed graphics cards
Disk FormatAPFS, APFS(Encrypted), Mac OS Extended (Journaled), Mac OS Extended (Journaled, Encrypted)
Si la respuesta te fue útil regálame un like, si resolvió tu problema, ¡Ayuda a otros usuarios a encontrarla aceptando la solución!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Saludos.
Licdo. Elmer Muñoz
Autodesk Certified Instructor | Training Manager | EESignature
¿Te ha parecido útil este post? ¡Deja un like!
Your question got successfully answered? Then just click on the 'Mark as solution'
0 Me gusta
mromagnoli
Solución aceptada
Estás realizando la instalación desde internet? 🙄
Estás en el administrador de tu cuenta o directamente desde la pagina de Autodesk🤔
Si estás en la pagina de Autodesk llegarás hasta esta ventana donde te pregunta la versión el SO y el idioma.
Te recomiendo que elijas la opción DOWNLOAD. De otra forma comenzará a instalar el programa al mismo tiempo que lo descarga y si tienes algún problema de conexión a internet, la instalación fallará.
En el caso de que estés descargando el programa desde el Administrador de Cuentas, te aparecen tres opciones.
De las cuales te recomiendo usar siempre Descargar ahora ya que utilizará el Download Manager para gestionar la descarga. Una vez que haya descargado todo el programa, podrás iniciar la instalación y no tendrás problemas de conexión a internet.
En ambos casos siempre es recomendable descargar el programa y despues instalarlo, utiliza el Autodesk Download Manager para que gestione las descargas que es mas rapido y es independiente al navegador de internet que tengas. Puede quedar abierto en segundo plano y irá descargando durante todo el dia y toda la noche si es necesario.
Espero que mi respuesta te ayude.
Saludos.
Arq. Marco Romagnoli
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
0 Me gusta
