La descarga llega al 38% y se congela.
¡Resuelto! Ir a solución.
Resuelto por mromagnoli. Ir a solución.
Resuelto por elmer.munoz. Ir a solución.
Hola @dcastilloBUW5U
¡Bienvenido a la comunidad Autodesk!
Verifica las características del sistema.
System requirements for AutoCAD LT 2023 (Windows)
Operating System | Microsoft® Windows® 11 or Windows 10 version 1809 or above. See Autodesk's Product Support Lifecycle for support information. |
Processor | Basic: 2.5–2.9 GHz processor (base) ARM Processors are not supported. Recommended: 3+ GHz processor (base), 4+ GHz (turbo) |
Memory | Basic: 8 GB Recommended: 16 GB |
Display Resolution | Conventional Displays: 1920 x 1080 with True Color High Resolution & 4K Displays: Resolutions up to 3840 x 2160 (with capable display card) |
Display Card | Basic: 1 GB GPU with 29 GB/s Bandwidth and DirectX 11 compliant DirectX 12 with Feature Level 12_0 is required for Shaded(Fast) and Shaded with edges(Fast) visual styles. |
Disk Space | 10.0 GB (suggested SSD) |
Pointing Device | MS-Mouse compliant |
.NET Framework | .NET Framework Version 4.8 or later |
System requirements for AutoCAD LT 2023 for Mac
Operating System | Apple® macOS® Monterey v12 Apple® macOS® Big Sur v11 Apple® macOS® Catalina v10.15 |
Model | Basic: Apple Mac Pro® 4.1, MacBook Pro® 5.1, iMac® 8.1, Mac mini® 3.1, MacBook Air®, MacBook® 5.1 Recommended: Apple Mac® models supporting Metal Graphics Engine Apple Mac models with M series chip are supported under Rosetta 2 mode. |
CPU Type | 64-bit Intel CPU Apple M series CPU |
Memory | Basic: 4GB Recommended: 8GB or higher |
Display Resolution | Basic: 1280 x 800 display High Resolution: 2880 x 1800 with Retina Display |
Disk Space | 5 GB free disk space for download and installation |
Pointing Device | Apple-compliant Mouse, Apple-compliant Trackpad, Microsoft-compliant mouse |
Display Card | Recommended: Mac native installed graphics cards |
Disk Format | APFS, APFS(Encrypted), Mac OS Extended (Journaled), Mac OS Extended (Journaled, Encrypted) |
Si la respuesta te fue útil regálame un like, si resolvió tu problema, ¡Ayuda a otros usuarios a encontrarla aceptando la solución!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Estás realizando la instalación desde internet? 🙄
Estás en el administrador de tu cuenta o directamente desde la pagina de Autodesk? 🤔
Si estás en la pagina de Autodesk llegarás hasta esta ventana donde te pregunta la versión el SO y el idioma.
Te recomiendo que elijas la opción DOWNLOAD. De otra forma comenzará a instalar el programa al mismo tiempo que lo descarga y si tienes algún problema de conexión a internet, la instalación fallará.
En el caso de que estés descargando el programa desde el Administrador de Cuentas, te aparecen tres opciones.
De las cuales te recomiendo usar siempre Descargar ahora ya que utilizará el Download Manager para gestionar la descarga. Una vez que haya descargado todo el programa, podrás iniciar la instalación y no tendrás problemas de conexión a internet.
En ambos casos siempre es recomendable descargar el programa y despues instalarlo, utiliza el Autodesk Download Manager para que gestione las descargas que es mas rapido y es independiente al navegador de internet que tengas. Puede quedar abierto en segundo plano y irá descargando durante todo el dia y toda la noche si es necesario.
Espero que mi respuesta te ayude.
Saludos.
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
