错误日志 2020/9/26:20:09:55 z1325 MAGICBOOK === Setup started on MAGICBOOK by z1325 === 2020/9/26:20:09:55 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:09:55 z1325 MAGICBOOK Current Directory D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm 2020/9/26:20:09:55 z1325 MAGICBOOK Launch 2020/9/26:20:09:55 z1325 MAGICBOOK CommandLine 2020/9/26:20:09:55 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:09:55 z1325 MAGICBOOK Current Directory C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp 2020/9/26:20:09:57 z1325 MAGICBOOK === Setup ended === 2020/9/26:20:09:56 z1325 MAGICBOOK === Setup started on MAGICBOOK by z1325 === 2020/9/26:20:09:56 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:09:56 z1325 MAGICBOOK Current Directory C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp 2020/9/26:20:09:56 z1325 MAGICBOOK Launch 2020/9/26:20:09:56 z1325 MAGICBOOK Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp\Setup\AcSetup.dll 2020/9/26:20:09:56 z1325 MAGICBOOK Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2020/9/26:20:09:57 z1325 MAGICBOOK PageOpen LaunchDialog 2020/9/26:20:10:00 z1325 MAGICBOOK PageOpen LicenseDialog 2020/9/26:20:10:03 z1325 MAGICBOOK PageOpen ProductInfoDialog 2020/9/26:20:10:03 z1325 MAGICBOOK PageOpen ProductSelectionDialog2 2020/9/26:20:10:11 z1325 MAGICBOOK PageOpen FullProgressDialog 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Install 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Install: turn off multi-threading 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::InstallAll 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Downloader: thread start... 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Dispatcher: thread start... 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Dispatch: assign DIRECTX to thread 0 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Installer: thread 0 start... 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing DIRECTX... 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:10:11 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:10:11 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:10:11 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:10:11 z1325 MAGICBOOK Installing DirectX Runtime: "D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2020/9/26:20:10:12 z1325 MAGICBOOK DirectX Runtime return code: -9 2020/9/26:20:10:12 z1325 MAGICBOOK Install DirectX Runtime Failed Failure is ignored, Result=-9 2020/9/26:20:10:12 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:10:12 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:10:12 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:10:12 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:10:12 z1325 MAGICBOOK InstallManager::LogProcessTime: DIRECTX downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: 1 2020/9/26:20:10:13 z1325 MAGICBOOK InstallManager::Dispatch: assign DIRECTX to thread 0 2020/9/26:20:10:13 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:10:13 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing DIRECTX... 2020/9/26:20:10:13 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:10:13 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:10:13 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:10:13 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:10:13 z1325 MAGICBOOK Installing DirectX Runtime: "D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2020/9/26:20:10:14 z1325 MAGICBOOK InstallManager::Dispatch: assign CM to thread 0 2020/9/26:20:10:14 z1325 MAGICBOOK DirectX Runtime return code: -9 2020/9/26:20:10:14 z1325 MAGICBOOK Install DirectX Runtime Failed Failure is ignored, Result=-9 2020/9/26:20:10:14 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:10:14 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:10:14 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:10:14 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:10:14 z1325 MAGICBOOK InstallManager::LogProcessTime: DIRECTX downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: 1 2020/9/26:20:10:14 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:10:14 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing CM... 2020/9/26:20:10:14 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:10:14 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:10:14 z1325 MAGICBOOK InstallHandler::Progress: CM 2020/9/26:20:10:14 z1325 MAGICBOOK Installing Autodesk Material Library 2021: ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk® AutoCAD® 2021" SETUP_PACKAGECODE={28B89EEF-4101-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={9046B381-E756-4D38-A7EF-FAD07F4456E6} ADSK_SOURCE_ROOT="D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2020/9/26:20:10:15 z1325 MAGICBOOK Install Autodesk Material Library 2021 Failed Installation aborted, Result=1625 2020/9/26:20:10:15 z1325 MAGICBOOK InstallHandler::Progress: CM 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::LogProcessTime: CM downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: 1 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Dispatch: assign CM to thread 0 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing CM... 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:10:15 z1325 MAGICBOOK InstallHandler::Progress: CM 2020/9/26:20:10:15 z1325 MAGICBOOK Installing Autodesk Material Library 2021: ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk® AutoCAD® 2021" SETUP_PACKAGECODE={28B89EEF-4101-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={9046B381-E756-4D38-A7EF-FAD07F4456E6} ADSK_SOURCE_ROOT="D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2020/9/26:20:10:15 z1325 MAGICBOOK Install Autodesk Material Library 2021 Failed Installation aborted, Result=1625 2020/9/26:20:10:15 z1325 MAGICBOOK InstallHandler::Progress: CM 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:10:15 z1325 MAGICBOOK Component: CM failed with code 16252020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::LogProcessTime: CM downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: NA 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: thread 0 detected global fatal error... 2020/9/26:20:10:15 z1325 MAGICBOOK InstallManager::Installer: thread 0 end 2020/9/26:20:10:16 z1325 MAGICBOOK InstallManager::Dispatch: assign CMILB to thread 0 2020/9/26:20:10:16 z1325 MAGICBOOK InstallManager::Dispatcher: thread end 2020/9/26:20:10:16 z1325 MAGICBOOK InstallManager::PostInstallAll 2020/9/26:20:10:16 z1325 MAGICBOOK DoASPUninstall: productCode = {317D67F2-9027-4E85-9ED1-ADF4D765AE02} 2020/9/26:20:10:16 z1325 MAGICBOOK verifyCertificates The file "C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp\Setup\SolutionProvider.dll" is signed. 2020/9/26:20:10:16 z1325 MAGICBOOK CertFindCertificateInStore C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp\Setup\SolutionProvider.dll Succeeded 2020/9/26:20:10:16 z1325 MAGICBOOK Failed to load C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp\Setup\SolutionProvider.dll. 2020/9/26:20:10:16 z1325 MAGICBOOK Could not fetch solution provider path from errors.xml 2020/9/26:20:10:16 z1325 MAGICBOOK verifyCertificates The file "C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp\Setup\SolutionProvider.dll" is signed. 2020/9/26:20:10:16 z1325 MAGICBOOK CertFindCertificateInStore C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp\Setup\SolutionProvider.dll Succeeded 2020/9/26:20:10:16 z1325 MAGICBOOK Failed to load C:\Users\z1325\AppData\Local\Temp\_AID6F8.tmp\Setup\SolutionProvider.dll. 2020/9/26:20:10:16 z1325 MAGICBOOK Solution Provider failed to load with error 36865. 2020/9/26:20:13:19 z1325 MAGICBOOK === Setup started on MAGICBOOK by z1325 === 2020/9/26:20:13:19 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:13:19 z1325 MAGICBOOK Current Directory D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm 2020/9/26:20:13:19 z1325 MAGICBOOK Launch 2020/9/26:20:13:19 z1325 MAGICBOOK CommandLine 2020/9/26:20:13:19 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:13:19 z1325 MAGICBOOK Current Directory C:\Users\z1325\AppData\Local\Temp\_AIF2AF.tmp 2020/9/26:20:13:20 z1325 MAGICBOOK === Setup ended === 2020/9/26:20:13:25 z1325 MAGICBOOK === Setup started on MAGICBOOK by z1325 === 2020/9/26:20:13:25 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:13:25 z1325 MAGICBOOK Current Directory D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm 2020/9/26:20:13:25 z1325 MAGICBOOK Launch 2020/9/26:20:13:25 z1325 MAGICBOOK CommandLine 2020/9/26:20:13:25 z1325 MAGICBOOK 另一个 Autodesk 安装/更新目前正在此计算机上运行。请等待该过程完成,然后再单击“重试”。2020/9/26:20:13:29 z1325 MAGICBOOK 另一个 Autodesk 安装/更新目前正在此计算机上运行。请等待该过程完成,然后再单击“重试”。2020/9/26:20:13:30 z1325 MAGICBOOK === Setup ended === 2020/9/26:20:13:20 z1325 MAGICBOOK === Setup started on MAGICBOOK by z1325 === 2020/9/26:20:13:20 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:13:20 z1325 MAGICBOOK Current Directory C:\Users\z1325\AppData\Local\Temp\_AIF2AF.tmp 2020/9/26:20:13:20 z1325 MAGICBOOK Launch 2020/9/26:20:13:20 z1325 MAGICBOOK Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\z1325\AppData\Local\Temp\_AIF2AF.tmp\Setup\AcSetup.dll 2020/9/26:20:13:20 z1325 MAGICBOOK Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2020/9/26:20:13:20 z1325 MAGICBOOK PageOpen LaunchDialog 2020/9/26:20:13:31 z1325 MAGICBOOK PageOpen LicenseDialog 2020/9/26:20:13:31 z1325 MAGICBOOK PageOpen ProductSelectionDialog2 2020/9/26:20:13:40 z1325 MAGICBOOK PageOpen FullProgressDialog 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Install 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Install: turn off multi-threading 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::InstallAll 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Downloader: thread start... 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Dispatcher: thread start... 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Dispatch: assign NLM to thread 0 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Installer: thread 0 start... 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing NLM... 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:13:40 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:13:40 z1325 MAGICBOOK InstallHandler::Progress: NLM 2020/9/26:20:13:40 z1325 MAGICBOOK Installing Network License Manager: ALLUSERS=1 ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk® AutoCAD® 2021" SETUP_PACKAGECODE={28B89EEF-4101-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={9046B381-E756-4D38-A7EF-FAD07F4456E6} ADSK_SOURCE_ROOT="D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2020/9/26:20:13:41 z1325 MAGICBOOK Install Network License Manager Succeeded 2020/9/26:20:13:41 z1325 MAGICBOOK InstallHandler::Progress: NLM 2020/9/26:20:13:41 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:13:41 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:13:41 z1325 MAGICBOOK InstallManager::LogProcessTime: NLM downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: 1 2020/9/26:20:13:41 z1325 MAGICBOOK InstallManager::Dispatch: assign CADM to thread 0 2020/9/26:20:13:41 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:13:41 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing CADM... 2020/9/26:20:13:41 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:13:41 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:13:41 z1325 MAGICBOOK InstallHandler::Progress: CADM 2020/9/26:20:13:41 z1325 MAGICBOOK Installing Autodesk CAD Manager Tools: INSTALLDIR="D:\CAD\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk® AutoCAD® 2021" SETUP_PACKAGECODE={28B89EEF-4101-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015-2019 Redistributable (x86),Microsoft Visual C++ 2015-2019 Redistributable (x64),;;;;" PACKAGEUPI={9046B381-E756-4D38-A7EF-FAD07F4456E6} ADSK_SOURCE_ROOT="D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2020/9/26:20:13:42 z1325 MAGICBOOK Install Autodesk CAD Manager Tools Succeeded 2020/9/26:20:13:42 z1325 MAGICBOOK InstallHandler::Progress: CADM 2020/9/26:20:13:42 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:13:42 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:13:42 z1325 MAGICBOOK InstallManager::LogProcessTime: CADM downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: 1 2020/9/26:20:13:42 z1325 MAGICBOOK InstallManager::Installer: thread 0 end 2020/9/26:20:13:42 z1325 MAGICBOOK InstallManager::Dispatcher: thread end 2020/9/26:20:13:42 z1325 MAGICBOOK InstallManager::PostInstallAll 2020/9/26:20:13:42 z1325 MAGICBOOK DoASPUninstall: productCode = {317D67F2-9027-4E85-9ED1-ADF4D765AE02} 2020/9/26:20:13:42 z1325 MAGICBOOK InstallManager::PostInstallAll: install successful 2020/9/26:20:13:49 z1325 MAGICBOOK === Setup started on MAGICBOOK by z1325 === 2020/9/26:20:13:49 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:13:49 z1325 MAGICBOOK Current Directory D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm 2020/9/26:20:13:49 z1325 MAGICBOOK Launch 2020/9/26:20:13:49 z1325 MAGICBOOK CommandLine 2020/9/26:20:13:49 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:13:49 z1325 MAGICBOOK Current Directory C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp 2020/9/26:20:13:50 z1325 MAGICBOOK === Setup ended === 2020/9/26:20:13:49 z1325 MAGICBOOK === Setup started on MAGICBOOK by z1325 === 2020/9/26:20:13:49 z1325 MAGICBOOK Path_Length: 107 2020/9/26:20:13:49 z1325 MAGICBOOK Current Directory C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp 2020/9/26:20:13:49 z1325 MAGICBOOK Launch 2020/9/26:20:13:49 z1325 MAGICBOOK Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp\Setup\AcSetup.dll 2020/9/26:20:13:49 z1325 MAGICBOOK Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2020/9/26:20:13:50 z1325 MAGICBOOK PageOpen LaunchDialog 2020/9/26:20:13:53 z1325 MAGICBOOK PageOpen BeginDeploymentDialog 2020/9/26:20:13:53 z1325 MAGICBOOK CBeginDeploymentDialog::OnInitDialog reads PATH_LENGTH: 107 2020/9/26:20:14:06 z1325 MAGICBOOK PageOpen LaunchDialog 2020/9/26:20:14:09 z1325 MAGICBOOK PageOpen LicenseDialog 2020/9/26:20:14:11 z1325 MAGICBOOK PageOpen ProductInfoDialog 2020/9/26:20:14:11 z1325 MAGICBOOK PageOpen ProductSelectionDialog2 2020/9/26:20:14:32 z1325 MAGICBOOK PageOpen FullProgressDialog 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Install 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Install: turn off multi-threading 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::InstallAll 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Downloader: thread start... 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Dispatcher: thread start... 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Dispatch: assign DIRECTX to thread 0 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Installer: thread 0 start... 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing DIRECTX... 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:14:32 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:14:32 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:14:32 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:14:32 z1325 MAGICBOOK Installing DirectX Runtime: "D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2020/9/26:20:14:33 z1325 MAGICBOOK DirectX Runtime return code: -9 2020/9/26:20:14:33 z1325 MAGICBOOK Install DirectX Runtime Failed Failure is ignored, Result=-9 2020/9/26:20:14:33 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:14:33 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:14:33 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:14:33 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:14:33 z1325 MAGICBOOK InstallManager::LogProcessTime: DIRECTX downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: 1 2020/9/26:20:14:34 z1325 MAGICBOOK InstallManager::Dispatch: assign DIRECTX to thread 0 2020/9/26:20:14:34 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:14:34 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing DIRECTX... 2020/9/26:20:14:34 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:14:34 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:14:34 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:14:34 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:14:34 z1325 MAGICBOOK Installing DirectX Runtime: "D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2020/9/26:20:14:35 z1325 MAGICBOOK InstallManager::Dispatch: assign CM to thread 0 2020/9/26:20:14:35 z1325 MAGICBOOK DirectX Runtime return code: -9 2020/9/26:20:14:35 z1325 MAGICBOOK Install DirectX Runtime Failed Failure is ignored, Result=-9 2020/9/26:20:14:35 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:14:35 z1325 MAGICBOOK InstallHandler::Progress: DIRECTX 2020/9/26:20:14:35 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:14:35 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:14:35 z1325 MAGICBOOK InstallManager::LogProcessTime: DIRECTX downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: 1 2020/9/26:20:14:35 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:14:35 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing CM... 2020/9/26:20:14:35 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:14:35 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:14:35 z1325 MAGICBOOK InstallHandler::Progress: CM 2020/9/26:20:14:35 z1325 MAGICBOOK Installing Autodesk Material Library 2021: ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk® AutoCAD® 2021" SETUP_PACKAGECODE={28B89EEF-4101-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={9046B381-E756-4D38-A7EF-FAD07F4456E6} ADSK_SOURCE_ROOT="D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2020/9/26:20:14:36 z1325 MAGICBOOK Install Autodesk Material Library 2021 Failed Installation aborted, Result=1625 2020/9/26:20:14:36 z1325 MAGICBOOK InstallHandler::Progress: CM 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::LogProcessTime: CM downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: 1 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Dispatch: assign CM to thread 0 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: thread 0 received new request... 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: thread 0 is processing CM... 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: locking sequential mutex 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: sequential mutex locked 2020/9/26:20:14:36 z1325 MAGICBOOK InstallHandler::Progress: CM 2020/9/26:20:14:36 z1325 MAGICBOOK Installing Autodesk Material Library 2021: ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk® AutoCAD® 2021" SETUP_PACKAGECODE={28B89EEF-4101-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={9046B381-E756-4D38-A7EF-FAD07F4456E6} ADSK_SOURCE_ROOT="D:\CAD\AutoCAD_2021_Simplified_Chinese_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2020/9/26:20:14:36 z1325 MAGICBOOK Install Autodesk Material Library 2021 Failed Installation aborted, Result=1625 2020/9/26:20:14:36 z1325 MAGICBOOK InstallHandler::Progress: CM 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: unlocking sequential mutex 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: sequential mutex unlocked 2020/9/26:20:14:36 z1325 MAGICBOOK Component: CM failed with code 16252020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::LogProcessTime: CM downloadTime: NA. pendingTimeBeforeInstall: NA. installTime: NA 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: thread 0 detected global fatal error... 2020/9/26:20:14:36 z1325 MAGICBOOK InstallManager::Installer: thread 0 end 2020/9/26:20:14:37 z1325 MAGICBOOK InstallManager::Dispatch: assign CMILB to thread 0 2020/9/26:20:14:37 z1325 MAGICBOOK InstallManager::Dispatcher: thread end 2020/9/26:20:14:37 z1325 MAGICBOOK InstallManager::PostInstallAll 2020/9/26:20:14:37 z1325 MAGICBOOK DoASPUninstall: productCode = {317D67F2-9027-4E85-9ED1-ADF4D765AE02} 2020/9/26:20:14:37 z1325 MAGICBOOK verifyCertificates The file "C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp\Setup\SolutionProvider.dll" is signed. 2020/9/26:20:14:37 z1325 MAGICBOOK CertFindCertificateInStore C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp\Setup\SolutionProvider.dll Succeeded 2020/9/26:20:14:37 z1325 MAGICBOOK Failed to load C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp\Setup\SolutionProvider.dll. 2020/9/26:20:14:37 z1325 MAGICBOOK Could not fetch solution provider path from errors.xml 2020/9/26:20:14:37 z1325 MAGICBOOK verifyCertificates The file "C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp\Setup\SolutionProvider.dll" is signed. 2020/9/26:20:14:37 z1325 MAGICBOOK CertFindCertificateInStore C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp\Setup\SolutionProvider.dll Succeeded 2020/9/26:20:14:37 z1325 MAGICBOOK Failed to load C:\Users\z1325\AppData\Local\Temp\_AI65FB.tmp\Setup\SolutionProvider.dll. 2020/9/26:20:14:37 z1325 MAGICBOOK Solution Provider failed to load with error 36865.
