I'm trying Autocad Structural Detailing 2013. However, I make a plan on ASD - steel, Object inspector tool is hided on workspace. Please show how show that tool. Thank all you very much
Hello everone,
I have same Object inpactor tool not appearing problem. The local Autodesk Premier supplier's technical support also could not make it appearent. If anyone know the solution that will be most appriciated.
Click the show/hide inspector button, move cursor to the very left of your boundary until you see a double arrow (with two horizontal lines in the middle) extend tool then drag right
