it would be very helpful if the structural steel grid appears in the orthographic view including the axis name.
Most of the Plant-users need to dimension to one of the steel axes but it is a great effort to create it with lines and mtext. If you dimension to one of the steel axes it hasnt the right "DIM-factor linar" and if you change the scale you have to scale and position the grid by yourself.
Thank you
