Show only
Search instead for
I propose bringing the MLEDIT option to edit intersections to P&ID SLINES. It would be even more ideal if this option could be defined from within the line class definition for Pipe Line Segments.
Regarding your proposal about the Mline option to edit the intersection goin as part of Pipeline segment, Exactly what I need on my project which is applying in my open channel line.
Unfortunately there's been no development done to alleviate this need. That said, my own workaround was to create a set of intersection tees that a user can place at the junction of any two or more multilines, similar to how a 3-way valve functions. This allows the tees to mask the otherwise overlapping lines. The only downside to using these, other than the fact that they must be manually placed after the fact is that you must create a unique tee for each unique mline style that varies in footprint.
