Revision control for report creator: MTO; BOM.
For the MTO (material take-off) and BOM (bill of materials) documents we need to keep track of changes on each item with a "revision" column. If there was a change in, for instance, length, the revision will increase, if not ,it stays the same.
My proposal is to have a Plant3D functionality to compare 2 extration files and give delta and revision index collumns automatically.
3 Comments
It would really facilitate those who want to use the report creator for mto extraction, which will allow us to know  whether the items have been modified, deleted or added with respect to the previous revision.
alex_xavier
This function are extremely necessary especially on large projects. I would ask Autodesk to give a special attention about this subject.
@Anonymous how you proceding with this subject? Are you doing it manually?
matthieu.macq
Please make this happen. We are highly struggling with external tools to manage it but it might better to have an integrated solution from P3DReporter included in a db. Thanks in advance for your consideration.
