P&ID intrument Group
Posibility to grouping in P&ID, instruments. Fro example - PT, PI, PAH, PAL in the same loop. The tarjet is assign for this objects group properties: Pressure, temperature of process line.
3 Comments
jason.drew
I created a brief video on TechSmith Screencast showing a workaround (assigning instrument loop numbers to signal lines groups):
http://www.screencast.com/t/GgI5aRdSSj6
George.Endrulat
@jason.drew Thank you for that link, that's good stuff.  Have you used this method and have you run into duplicate tag number errors because of it?
jason.drew
It is possible to end up with duplicate loop numbers on the signal lines using the method shown in the video, even with using the loop number property as a line group property. It's still not able to check for duplicates due to some of the limitations of tagging signal lines.
I have not found a way around that other than "hacking" the project P&ID database so to speak (PnPTagEnlistedColumns table), which is not recommeded.
