In my example, you can see I have two olets which flow in different directions. The direction of the branch bend shows the direction of the flow. It is required to have the ISO symbol match this direction in the Isometric diagram.
3D Model
Line 001
Line 002
The problem is the Spec Editor does not give the property 'Flow Dependency' to the Olets. Therefore the ISO symbols do not flip to match the direction of the flow in the same way items such as the valves does.
Valve Catalog Entry
Olet Catalog Entry
You can see that my ISO symbol for the Olet has the correct flip action but the ISO symbol does not flip.
Valve ISO Symbol
Olet ISO Symbol
Hopefully, there is a workaround for this other than manually editing the isometric drawing.... if not I feel the property should be added to the Olet catalog properties.
