Multi line tag attribute in Plant P&ID
We have the option to make a multi line attribute (specifically in the instrument bubbles) in the block editor of Plant P&ID along with modifying the paragraph line spacing between the lines.  When placing the tag on the P&ID, only the multi line attribute worked but not the spacing.  I worked with Dave Wolfe and Quentin Contreras but were not able to get it to work.  This feature is useful since on a case by case basis, we use a third line under the loop number within the instrument bubble and are limited in space.
