Miter cut
Miter cut
Hi, Does anyone know if Autodesk is going to implement a good function for miter cut pipes? I see from the forum that it was mentioned in 2017...But still not implemented...🤔
1 Comment
RickFrance
This is already in the catalog templates for pipe. You can also get to it via the Custom Parts. However, it has a 3 section minimum which means you can't do a single 45 deg miter, but it works well for all others.
