Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Insulation breaks on line number
The ability add partial insulation on the same line number (i.e. insulate outside portion of a line but leave inside portion uninsulated).
2 Comments
rbrennan7BK6M
Hi, This would be nice to have a UI driven approach. I wanted to share that if you are not aware, you can select say, the inside portion of the pipe once you've assigned the line properties, and do an override on insulation thickness for the selected parts. This achieves this on the ISO content side at least. I think there may be some questions for the Line data side
jpatflora
Hey! Thanks for the reply. I am aware of the work around to get the insulation break to appear on the isometric. I, like you, think there should be a way to do this besides putting the property in "override" mode. And you are correct on the line list. If you export the line list with a portion of the line insulated, it shows the entire line insulated per the pipe line group.
Thanks!
