Improvement to sort order for 'Connect Off-page Connector' Window
When selecting an off-page connector, right-clicking, and then selecting Connect, the dialog that comes up shows the drawings which it can connect to. There is no discernible order and it makes it difficult to locate the drawing we need. Suggested by: SSOE Group
7 Comments
jason.drew
Status changed to: Gathering Support
jason.drew
dave.tyner
Agreed, there is a work-around for this for SQLite which can be found here.
https://screencast.autodesk.com/Embed/Timeline/17c9a137-8bc7-49c6-8f68-1a368b42a77e
READ THE DISCLAIMER 🙂
George.Endrulat
@dave.tyner That workaround you posted is amazing.  I just can't thank you enough.
craig_wood
Thanks for the workaround! Will use that for now. Otherwise, kudos Jason! Please do alpha-numeric sorting at a minimum. Anything makes more sense than drawing creation date Smiley Frustrated
craig_wood
I just realized that 2016 SP1 addresses this concern. Is there any way to close out an idea once it's been adopted and applied?
Craig
erhan_saupe
@jason.drew
Even though this entry is a bit older, for the sake of completeness, I would like to add that there is a tool that significantly improves the OPC management function.
Check out:  Off-Page Connector Manager (OPC Manager) by auxalia
