Hose instead of pipe
We need to connect machines via flex hoses to the fixed pipelines. But plant 3d dont know nothing about hoses. This should be changed urgently.
27 Comments
The ability to insert a flexible hose which is also recognised on the isometric is of high importance to me, as i have hundreds of these things in my model. At the moment, the only fix I have is to manually change each isometric!
Arun_Kumar_K
This feature is important one.
I agree, flexible hoses are often a significant item on a skid.  It takes too long to model them, then have to add them back in to a n Iso!
damian_willcox
Hi there,
We have added "Pulled Piping" in our 2017 release which may help with this.
Try it out and let us know your thoughts.
thanks,
-damian
I would like to see this as well!
damian_willcox
Hey everyone,
We keep getting votes on this, and I had commented before, but I am wondering if anyone has used the new "Pulled Piping" we released in our 2017 version to do their tubing with?  This builds on and integrates with the previously existing "Pipe Bend" functionality and allows you to continuously route and bend pipe as a single object with no elbows/welds/etc.
Please let us know your thoughts on this, and if this fits your needs for tubing or if you require anything beyond this.
-damian
dave.wolfe
I think you could close it. Between the pulled pipe, and being able to create a "flexible" component, I think this one would be considered covered.
damian_willcox
Thanks very much Dave!
All,
I will mark this as implemented. If there are any remaining aspects of pulled piping or tubing support that you are having issues with please feel free to post a new Ideastation suggestion or ask in our forums.
thanks very much.
-damian
damian_willcox
Pulled Piping support has been added in 2017 and supports multi bend single pipe modelling and reporting in Iso, etc.
(rounding out the pipe bend functionality we initially started a few years back, but weren't able to take on the full scope of work in one shot - thank you for your patience)
I'm good with marking this as "implemented"
damian_willcox
Great, thanks @Anonymous!
-damian
damian_willcox
Status changed to: Archived
Archiving the implemented feature.
Ruffy85
Sorry, but Flexible Hoses is something different as Pulled Pipes
Please implement this like in Inventor!
Flexible pipe and dual contained pipe is required in Plant
as far as flexible hose is considered, the expansion joint object of cadworx is a good reference, but have to say as well, the expansion joint of cadworx works well as a straight inline component, you can input the length you required, but it does not work if it is an offset installation;
Pakrac
Observer
This will be very helpfull when added!
I would be great if Pigtail Connections can be added.
We have a continuous flexible pipe that serves as direct lines from a manifold to various equipment. We would like the total length of the pipe run labeled. Also, the runs could occasionally have a tee splitting service to two pieces of equipment. Again, we would like the label to include length to the tee and then the lengths to each piece of equipment. Is this feature available or is this something that still needs to be added?
damian_willcox
@Anonymous
You may be able to get what you need for this from the pulled pipe feature - when toggled on, it will route a continuous pipe with control over bends, etc, and you can still place components. You should see the total pipe length in the Properties Palette, as well as in the BOM when running an isometric. Hope that helps some.
@damian_willcox , that would mean having to go to Project Setup and select Treat Bends as Pipe. Can we have a dedicated tool that offers a direct approach to modeling hose connections?
