Generate Isos by line and Sheet Number
We need to be able to Generate Isos by Line # and Sheet #.
At all places I have worked we have never been able to use the full functionality of plant 3D as we have had to add a sequential number to the end of our line numbers so we can run individual sheets for isometrics.
I'm aware you can have fixed split points, however when you often have between 1 - 30 sheets for a single line number it's very impractical to re run all sheets every time you need to update a single isometric.
So as I've mentioned above our work around is adding sequential number to the line number tag. This means that we can never use the P&ID link.
If the Isos generation selection could be done by line # and Sheet # that would fix that issue. Or enable a user defined model property to generate the isos from. or enable P&ID to 3D to validate to a field other then the line number tag (user defined)
Regard
Wayne
