Coordination system, multidisciplinary, project, Plant 3D, Autodesk solutions
Working on a project with Civils, Arch, MEP, Structural, and Plant3d. C, A, S are all set to have real-world shared coordinates. Plant3d can only work in WCS (True North) as the ISOs do not appear correctly (changing the offset location for each ISO is not an option). Can Plant 3D future releases be able to accommodate any other coordinate systems? This will benefit the readability of coordinates in the generated Isometric drawing.
1 Comment
RickFrance
You can set the coordinates globally for all the isos in the project setup.
