Calculated fields are not in the project set up available
I have some fields which I want to calculate within the P&ID. For example the test pressure in some projects are always the design pressure * factor for
all pipes.
To be able to do this I have to go into one drawing and use the Definecalproperties tool to do this. Unfortunately these fields are not available in
the project set up like other fields created in the project set up. Acquisition of this field is not possible.
In addition users which are not knowing about the set up will never find out where the calculations are coming from.
So my suggestion is that the caluclated fields should be available in the "add property" menu. Then I would be created there in the project set up
and would be easy to follow up.
See attached picture.
2 Comments
You can easily do that with the PLANTDEFINECALCPROPERTIES command, there you can do quite a bit of math / composition of properties.
Vicky.Wu
Starting from AutoCAD Plant 3D 2023 RTM, you can now customize calculated properties from Project Setup.
For more details, see Help:
https://help.autodesk.com/view/PLNT3D/2023/ENU/?guid=GUID-9748587E-8BB9-4704-A849-A8A4D163C334
Would you please give it a try and let us know your feedback?
