Automatically determine and store operator-facing direction for valve actuators in AutoCAD Plant 3D
Description:
Currently in AutoCAD Plant 3D, while the actuator orientation (e.g. the rotation axis of a handwheel) is defined and can be exported through PCF or displayed on isometrics, there is no built-in mechanism to determine the direction in which an operator would physically stand to operate the valve.
For example, if a handwheel is mounted on the east face of a valve, the operator would logically face west when approaching it. This operator-facing direction is important for:
  • Installation planning
  • Ergonomic checks
  • Operations and maintenance documentation
  • Generating clear instructions and annotations on isometric drawings
Currently, the only workaround is to manually assign a custom property like OPERATOR_DIRECTION, which is time-consuming and error-prone. It also introduces inconsistency, especially across large projects or automated workflows.
Request:
Add native functionality in AutoCAD Plant 3D to:
  1. Automatically determine the operator-facing direction based on valve and actuator geometry at insertion.
  2. Store this direction in a property (e.g. OperatorDirection) that can be:
    • Exported into PCF
    • Used in Data Manager
    • Displayed in annotations on isometric drawings
  3. Optionally provide a visual cue in the model for operator-facing side during design.
Benefits:
  • Reduces user error by removing manual data entry
  • Enhances accuracy of fabrication and operation documents
  • Enables more intelligent data automation (e.g. for scripts or exports)
  • Provides consistent metadata across large projects
