Show only
Search instead for
Is it possible for the sub folders within a project to have a relative file path instead of a fixed one, similar to the way drawings and models are, any help on this would be great,
Could you explain what your issue might be? I'm not following the need for a Relative Path for sub-folders. When you create a sub-folder in the Project it creates it in Windows as well. If you move a project to a new location or use a project as a template for another project, then all sub-folders will update accordingly so they are basically all relative to the project to begin with. It makes sense for an XRef, but you can already set those up as Relative. I am just not following what you are seeing as an issue.
