Auto Generated Spool ID's (Numbers) Need To Match In All Isometric Themes
Currently if I generate Spool ID's to be added in two different Isometric Themes with different Drawing Types for the same Line Number, the isometric will assign different Spool ID's for each theme. The Spool ID's (Spool Numbers) should be the same in every Isometric Theme without having to manually add a Spool Number to the Model. The isometrics have the same Starting point and same components so the Spool ID's should be the same whether using the Isometric Drawing Type or the Spool (Fabrication) Drawing Type.
