Add Steam Trap to Catalog Editor
Per this article:
https://forums.autodesk.com/t5/autocad-plant-3d-forum/add-3d-model-of-steam-trap-as-piping-component...
Requesting the addition of Steam Trap to the Miscellaneous category in the Catalog Editor.
@safia.mohamed022
@rajendra.prajapat
@Tomislav.Golubovic
@alexalvandi
@h_eger
@patpat79
2 Comments
h_eger
@brettbarkman ,
well, as you can see, a steam trap has the same functionality as a check valve.
In my case, the steam trap is created in the valve class.
brettbarkman
Yes I thought valve was the closest too. Just figured it might make sense having that as its own choice because in P&ID there is a class for Steam Trap under Piping Specialty Items like a strainer for example, however there is no mention of it on the Plant 3D side.
