Zero ground level
Zero ground level
Zero ground level
Hi
I am new user in plant 3d currently I m working on projects which I need to create below ground and above ground pipe work but I don't know how to setup ground level or zero plane also every time I measured hight I don't get distance from ground level please let me know
patpat79
Many ways to do what you want. I suggest, hope itll work, set your ground eleveation first (eg. el +25000, el+ 1000, or just 0). Then you can always use the autocad command "ID" to know the elevation (or exact coordiante x,y,z) of your piping or component or pipe run. To be more precise, heres what i do, first, I identify the clients plant grade level (eg. EL+ 29500). then i create a polyline or rectangle and move it to the elevation required, extrude it to downward direction, then, you can use the "DI" command to measure the exact x,y,z of your piping to the x,y,z of the grade elevation, thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Thanks mate this would be helpful also what's the easiest way to set up elevation ( for example I want ground level at 1000mm or 0)
Once again thanks
Sent from my iPhone
