AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Workspace Gone??!!!
7 REPLIES 7
Message 1 of 8
805 Views, 7 Replies
Workspace Gone??!!!
I am using Plant 3D 2019 but it doesn't display any workspaces or tabs on the ribbon.
Do i have to customise these or can i just reload the standard ones?
Not had this issue before with previous versions
7 REPLIES 7
Message 2 of 8
Slawomir_
Can you post print screen of Plant 3D window?
Message 3 of 8
in reply to: Slawomir_
Screenshots of the Plant 3D screen
Message 4 of 8
Slawomir_
Message 5 of 8
Slawomir_
Have you found solution to your problem?
Message 6 of 8
No i'm afraid the problem isn't solved
I have reloaded the cuix file but nothing changes
I will try to reset to defaults again but nothing has happened so far
Message 7 of 8
JUANCARLOSBLASCO4129
Plant 3d 2019 doesn't have "reset settings to default" like autocad.
If load cuix doesn't work, or you don't have a backup of you cuix, i would reinstall plant 3d.
Regards
Message 8 of 8
autocad plant 3d like auto cad, has a section where you can find diferent "profiles". you need to introduce the comand "option" and enter to the section "profiles". it is posible that your profile was change. Check that the profile <<Unnamed Profile>> is selected.  may be could works. good look
