Working a Plant 3D model into Inventor
- Mute
- Permalink
- Report
I'm working a large Plant 3D model. I was struggling to work with the dwg files because when I was import the dwg files as xrefs the files were so large that I wasn't able even to rotate the model. So, I used Navisworks in roder to cretae nwc files to reduce the file size. Then I imported the cordination models and now it is working much better. The thing is that there isn't any snap point. My aim is to cretae cable trays which will running through a big building (which including pipes, pumps etc) but I'm not able to attach the cable tray for example onto an I beam. I thought to export a dwg model and importing it into Inventor, so I'll be able to create the cale trays more easy. However, when I import the dwg into Inventor there is no any 3D solid.
I would appreciate any help
Thanks!
