Hello, when I open some drawing in autocad plant 2024 this message appears
I had already tried to switch perspective view to off and restart the auto cad, but nothig has worked
pls someone help me :(((😥😥😥
Solved by jabowabo. Go to Solution.
You may find some useful suggestions here:
https://forums.autodesk.com/t5/autocad-forum/walk-fly-pop-up-when-panning-or-3dorbit/td-p/6457978
https://forums.autodesk.com/t5/autocad-plant-3d-forum/perspective-parallel-view/td-p/10845273
https://forums.autodesk.com/t5/autocad-plant-3d-forum/perspective-view/td-p/5504572
