Viewcube disappears in AutoCAD Plant 2022
philip.barcy
philip.barcy
While I was working on the 3d drawing then the viewcube and navigator disappears, i tried to put it back on but it is already on (!) Please advise what is the issue with it.
I am working on AutoCAD Plant 2022.
Phil
@philip.barcy
Topic Title has been changed for better findability by @joaquim.moral Original Post: Viewcube disappears!
h_eger
Dear @philip.barcy ,
what visual style do you work with?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
popovUS9BY
... since I working 3D only, I got same issue.
philip.barcy
Realistic visual style
George.Endrulat
try the CUBE ON command
George
If my post offers a solution, please click "Accept as Solution"
rajendra.prajapat
@philip.barcy please try this command DISPLAYVIEWCUBEIN3D & it should be on.
brian.yowell
Kudo's- I was working on orthographic drawing and was set to wireframe (no cube). I switched to realistic view and it appeared. Shaded also works. Switching to Conceptual everything in Ortho box is hidden by the actual box itself...
Thanks again...
