AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Vertical dimension in plant 3d model
2 REPLIES 2
s.strat
405 Views, 2 Replies
Hello. I am struggling to get a vertical dimension in plant 3d. For example if a try to get a dimension from the node of the bend to the node of the flange the dimension i have is still horizontal and not a vertical dimension(Please see photo attached)
Labels (1)
2 REPLIES 2
h_eger
in reply to: s.strat
Dear @s.strat ,
rotate the UCS to the respective level and use 3D manning from AutoCAD
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
The command line should show the distance, and the delta values between the points.
