Valve Operator Orientation
joshuaaS6HAW
joshuaaS6HAW
Hello, In Plant 3D how do you change the valve operator to Normally Open or Normally Closed position? Kindly give a note. Thanks in advance.
h_eger
Dear @joshuaaS6HAW ,
1. Create a 2. symbol for the closed state and add it to the open symbol
2. In the Normaly line, mark the symbol list and go to edit
3. Now select the new symbol for the closed state of the valve in the NC line.
In the properties you can now change the display in the P&ID via NO and NC
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
joshuaaS6HAW
Thank you
joshuaaS6HAW
For P&ID, its very much useful. For model, Lever operated valve, how could I make turn off position of the valve lever?
h_eger
Not at all because the model is already in the finished control valve as it was defined in the P&ID. The P&ID is the leader in planning, not the 3D model.
Hartmut Eger
Senior Engineer
XING | LinkedIn
