AutoCAD Plant 3D Forum
Valve Description not updated in Valve List
3 REPLIES 3
pradeep.walse
194 Views, 3 Replies
I have modified Valve list report od Plant P&ID as per my requirement. It contains line number, size, tag, specs, and item description. Refer below snap shot.
If we update the line size by edit annotation from 6” to 4” then it is not updating it in item description.
We have added required item description of valve in specs in ‘Long Description(Size)’ in PMS because we are using the same specs for 3D piping modelling.  In report, I used ‘Inline asset_Specs Part’ to get item description in Valve list report.
We also observed that after changing line size from 6” to 4” same is also not updating in ‘Specs part’ column of data manager of P&ID.
Refer attached PDF file more additional information.
Request you to please suggest the solution for this problem.
3 REPLIES 3
h_eger
in reply to: pradeep.walse
@pradeep.walse ,
In which product description did you find the information that this should work in Plant 3D P&ID?
I am not aware that the attribute flow can cause a change in the way you work.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
pradeep.walse
in reply to: h_eger
@h_eger ... I have not found any product description. But I though it will work. So tryng it.
h_eger
@pradeep.walse ,
that was exactly the small error because there is no data update when the nominal width is changed.
This would require a little more customisation in P3D with external tools.
Hartmut Eger
Senior Engineer
XING | LinkedIn
