AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
union cotation isometric
12 REPLIES 12
Message 1 of 13
1328 Views, 12 Replies
It's possible to make cotation for union in isometric?
View the pic.
12 REPLIES 12
Message 2 of 13
Bernd.Gerstenberger
I understand that you want to have a dimension from the mid of the elbow to the part component annotated by a 3. Am I right? If yes, what for an iso symbol type and SKEY does this component have?
Bernd G.
Senior Product Support Specialist
Message 3 of 13
in reply to: Bernd.Gerstenberger
That's exactly, i want the annotation the middle of the elbow to the middle of the union.
see the pic for iso symbol and skey.
Message 4 of 13
Bernd.Gerstenberger
Here you go: Open isoconfig.xml with a good xml editor like XML Notepad. Switch to the node "Themes - Theme (name= Default) - Dimensions - DimensionTypes - DimensionType (name = String) - AnchorPoints. Create here a new Anchorpoint. Call it e.g. "Union", enable it and set the filter to "Union" (this filter already exists by default). For the end points set "Center". See here:
Please, let us know if I could help you.
Best regards
Bernd
Bernd G.
Message 5 of 13
Hi, i add the anchor like you told me to do and the result isn't there, maybe i do something wrong.
I sent to you my iso.config
Thank you
Message 6 of 13
Bernd.Gerstenberger
Hi, thank you for the isoconfig.xml. I have found 3 issues:
  1. The anchor point was added to DimensionType "Overall" instead of "String".
  2. The anchor point was placed on the wrong level. It was placed as an anchor point for another anchor point. Which has resulted in an error when I try to get the xml-file opened via XML Notepad.
  3. From the snapshot from you, I could see that the size of the pipe line is 25. By default all sizes equal or less 50 are belonged to the "Small Bore Piping"-theme. You can set this borderline in project setup, node "Isometric DWG Settings - Dimension", at the bottom you see "Small Bore Piping up to and including" with a selection list. Here you can set different values.
    1. About Small Bore Piping Theme: By default components which are falling into Small Bore Piping theme have less annotations and less dimensions in isometric drawings.
    2. I have enable the string-dimension for Small Bore Piping Theme in isoconfig.xml and have added here as well the anchor point for Union. See attached Snapshot
Attached is also the updated isoconfig.xml.
Best regards
Bernd
Bernd G.
Message 7 of 13
thanks for your reply,
i use your iso.config and i set it up Small Bore Piping up to and including to 6.
i cannot have my union annotation. 😞
Message 8 of 13
Bernd.Gerstenberger
Please, send me your model drawing and your zipped iso style folder.
Bernd G.
Message 9 of 13
Can i send to you by email?
the file is to big, i can send to you by we transfer.
Message 10 of 13
Bernd.Gerstenberger
We have an open case together. Here is an article how to attach big data to case.
Bernd G.
Message 11 of 13
did you receive it?
Message 12 of 13
Bernd.Gerstenberger
Yes, I've got it. I have attached your modified iso style Prefa_A3. Use this iso style to get the correct isometric of the content of drawing2.
Please, let us know.
Bernd G.
Message 13 of 13
That's great. thank you so much.
Can we solve also the weld list problem?
Thank you
