Unhandled Exception when trying to open isometric borders for editing
Message 1 of 15
"Object reference not set to an instance of an object".
This error appears whenever I try to edit an isometric border from the project settings dialogue. It doesn't seem to matter which iso style I'm in. When I hit continue, nothing happens - the border is not opened.
The full log is attached as a text file.
Replies (14)
Message 2 of 15
It seems that the error only occurs in a specific project, but I have no idea what could be causing the error.
Message 3 of 15
Any ideas? I don't know what the object reference could be. The .dwt file itself?
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.ProcessPower.PnP3dIsoUI.PnPIsoSettingsManager.SaveIsoSettings()
at Autodesk.ProcessPower.PnPProjectSetup.IsometricConfigureTitleBlockUserControl.button_Setup_Blk_Click(Object sender, EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Message 4 of 15
jabowabo
Plant is particular about how the title block is named. Check to make sure yours has not been changed.
Message 5 of 15
Yeah, I discovered that when I had a title block that was disappearing in another project.
The title block in this .dwt file is just called "Title Block", which I think is correct. That wouldn't explain why the same error occurs for all of the isometric styles, though, since they still have their default templates and values.
There must be another setting in the project that's breaking the title block setup when it tries to load.
Message 6 of 15
dave.wolfe
Have you ran a RECOVER on the template? Create a backup first.
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
Piping Labs
Message 7 of 15
0 errors found, same as when I ran audit.
Thanks for your suggestions.
I may just have to make a new project and try to incorporate the customisations I remember from this one. I don't feel like I've changed anything that could create this error, though.
Message 8 of 15
dave.wolfe
Create a backup, and then drop in the template (match the template file names) from a stock iso style. Do you still get the error?
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
Piping Labs
Message 9 of 15
Same error: as soon as I click "Setup title block", the exception appears. The same thing happens even if I choose one of the default styles (Check A2 etc).
I should note that the isos still run fine in this project, so Plant is still finding a valid template to populate.
Message 10 of 15
dave.wolfe
Is there anything in the error log?
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
Piping Labs
Message 11 of 15
The iso error log? There are some warnings, but those were there before this problem started.
Iso Creation start time : 12/01/2016 14:48:16
Iso Creation finish time: 12/01/2016 14:48:29
Duration : 00:00:13
Output folder : L:\Design\PIPING\Plant 3D Project\Client\Project\Isometric\OPT_A2\ProdIsos\Drawings
1 Isometric(s) successfully created with no error conditions:
L:\Design\PIPING\Plant 3D Project\Client\Project\Isometric\OPT_A2\PCFs\TEST-NEW.pcf
INFO - Loading input: 'L:\Design\PIPING\Plant 3D Project\Client\Project\Isometric\OPT_A2\PCFs\TEST-NEW.pcf'
INFO - Loaded '2' model(s).
INFO - Processing: 'TEST-NEW-1'.
WARNING - No break points have been specified.
INFO - Model-split has been skipped.
WARNING - Resize defined that model TEST-NEW-1 may need splitting
WARNING - Invalid filter expression: 'Existing = 'false' AND SpoolNumber <> '''.
INFO - Processing: 'TEST-NEW-2'.
INFO - Generated drawing: 'L:\Design\PIPING\Plant 3D Project\Client\Project\Isometric\OPT_A2\ProdIsos\Drawings\2107-1.dwg'.
INFO - Generated drawing: 'L:\Design\PIPING\Plant 3D Project\Client\Project\Isometric\OPT_A2\ProdIsos\Drawings\2107-2.dwg'.
WARNING - No tables are configured to be exported.
The exception error log in its entirety is attached to the first post.
Message 12 of 15
Did a solution ever present itself regarding this issue?  I am currently experiencing this same problem of trying to manipulate the iso.dwt file and getting the debugging error.  I have started a new project and copied my piping into a new folder, then changed the spool title block to the companies, and now I am getting a debugging error when I try to manipulate the block by selecting the "Setup Title Block".
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1076.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 21.0.0.0
Win32 Version: 21.0.52.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL
adui21
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL
AdUiPalettes
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL
WindowsBase
Win32 Version: 4.6.1080.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
Win32 Version: 4.6.1055.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
Win32 Version: 4.6.1075.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
AdApplicationFrame
Win32 Version: 2015.11.1.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL
AdWindows
Assembly Version: 2015.11.2.0
Win32 Version: 2015.11.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 4.6.1067.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
Win32 Version: 4.6.1068.2 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
BIM360GlueAutoCAD2017Addin
Assembly Version: 4.37.6853.0
Win32 Version: 4.37.6853.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAutoCAD2017Addin.dll
BIM360GlueAddinsCommon
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAddinsCommon.DLL
log4net
Assembly Version: 1.2.11.0
Win32 Version: 1.2.11.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/log4net.DLL
FeaturedAppsPlugin
Win32 Version: 21.0.46.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2017/Win64/FeaturedAppsPlugin.dll
PnIDDrawingOverrule
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnIDDrawingOverrule.dll
PnPDataLinks
Assembly Version: 8.0.0.0
Win32 Version: 8.0.52.02
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PnPDataLinks.DLL
PnPCommonArx
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pnpcommonarx.arx
PnPProjectManager
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/PnPProjectManager.arx
PnPProjectManagerMgd
Assembly Version: 8.0.52.2
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPProjectManagerMgd.dll
PnPCommonMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PnPCommonMgd.DLL
PnIDMgdInternal
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pnidmgdinternal.dll
PnIDUIMgd
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pniduimgd.dll
PnPCIP
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pnpcip.dll
PnIDCIP
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pnidcip.dll
PnIDMain
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pnidmain.arx
PnP3dMain
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pnp3dmain.dll
PnP3dPartsRepository
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PnP3dPartsRepository.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
PnP3dContentMgd
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/PnP3dContentMgd.dll
PnPCommonArxMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPCommonArxMgd.dll
PnP3dObjectsMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dObjectsMgd.dll
PnP3dPipeUI
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pnp3dpipeui.dll
PnPValidation
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPValidation.dll
PnIDDwgValidation
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnIDDwgValidation.dll
PnIDDwgValidation.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnIDDwgValidation.resources.DLL
PnP3dSpecUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dSpecUI.dll
PnP3dSpecUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnP3dSpecUI.resources.DLL
PnPNewTabPageUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPNewTabPageUI.dll
PnPProjectManagerUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPProjectManagerUI.DLL
Autodesk.Connectivity.Explorer.ExtensibilityTools
Assembly Version: 22.0.0.0
Win32 Version: 22.0.40.2
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/Autodesk.Connectivity.Explorer.ExtensibilityTools.DLL
PnPProjectManagerUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnPProjectManagerUI.resources.DLL
PnPRevisionCloud
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/pnprevisioncloud.dll
XDbReferenceManagerArx
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/XDbReferenceManagerArx.dll
XDbReferenceManagerArx.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/XDbReferenceManagerArx.resources.DLL
PnP3dOrthoDrawingsUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dOrthoDrawingsUI.DLL
PnPDwg2dUtil
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPDwg2dUtil.DLL
PnPDwg2dDbx
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPDwg2dDbx.DLL
PnP3dOrthoDrawingsUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnP3dOrthoDrawingsUI.resources.DLL
PnPDwg2dAnno
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPDwg2dAnno.DLL
PnP3dIsoUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dIsoUI.DLL
Autodesk.AutoCAD.Interop
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Autodesk.AutoCAD.Interop.DLL
Autodesk.AutoCAD.Interop.Common
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Autodesk.AutoCAD.Interop.Common.DLL
PnP3dProjectPartsMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dProjectPartsMgd.DLL
PnPDataObjects
Assembly Version: 1.0.5896.38471
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PnPDataObjects.DLL
PnPUtilMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPUtilMgd.DLL
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
PnIDProjectPartsMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnIdProjectPartsMgd.dll
PnIDProjectPartsMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnIDProjectPartsMgd.resources.DLL
PnP3dDataLinkManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PnP3dDataLinkManager.DLL
PnP3dOrthoProjectPart
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dOrthoProjectPart.dll
PnPSQLiteEngine
Assembly Version: 1.0.5896.38480
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PnPSQLiteEngine.DLL
System.Data.SQLite
Assembly Version: 1.0.65.0
Win32 Version: 1.0.65.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/System.Data.SQLite.DLL
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
PnP3dConnectionManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dConnectionManager.DLL
PnIDProjectParts
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/PnIDProjectParts.Arx
PnPCommonUIMgdCs
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPCommonUIMgdCs.DLL
PnIdGuiUtils
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/PnIdGuiUtils.dll
PnIDGUIUtilMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnIDGUIUtilMgd.dll
PnIDGUIUtilMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnIDGUIUtilMgd.resources.DLL
PnP3dProjectParts
CodeBase: file:///c:/program%20files/autodesk/autocad%202017/plnt3d/PnP3dProjectParts.arx
PnP3dObjects
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PnP3dObjects.dbx
PnP3dCustomControlLibrary
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dCustomControlLibrary.DLL
PnP3dPlantContentUpgrade
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dPlantContentUpgrade.dll
PnP3dProjectManagerUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dProjectManagerUI.dll
PnP3dProjectManagerUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnP3dProjectManagerUI.resources.DLL
PnPCommonUIMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPCommonUIMgd.DLL
PresentationFramework-SystemData
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll
PnP3dWorkspace
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dWorkspace.dll
PnP3dCOGUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dCOGUI.DLL
PnP3dCOGUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnP3dCOGUI.resources.DLL
PnP3dWorkspace.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnP3dWorkspace.resources.DLL
PnP3dSpecManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PnP3dSpecManager.DLL
PnP3dPartsRepository.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/PnP3dPartsRepository.resources.DLL
PnPDwg2dDef
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPDwg2dDef.DLL
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/Microsoft.Expression.Interactions.dll
PnPCommonDbxMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPCommonDbxMgd.DLL
ClicJsInfoCenter
Win32 Version: 3.1.26.0
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/CLM/V3/MSVC14/ClicJsInfoCenter.dll
PnP3dDataManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dDataManager.dll
PnPDataGrid
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPDataGrid.DLL
PnPDataGrid.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnPDataGrid.resources.DLL
PnP3dDataManager.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnP3dDataManager.resources.DLL
AcLivePreviewContext
PnIDWorkspace
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnIDWorkspace.dll
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayer.resources.DLL
PresentationFramework.Luna
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcMrUI.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMrUi.resources.DLL
FeaturedAppsPlugin.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2017/Win64/en-US/FeaturedAppsPlugin.resources.DLL
PnP3dCommonUIMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dCommonUIMgd.DLL
PnPIsoCore
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnPIsoCore.DLL
PnP3dIsoDbx
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dIsoDbx.DLL
PnP3dInteropUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dInteropUI.DLL
PnP3dInterop
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/PnP3dInterop.DLL
PnP3dInteropUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnP3dInteropUI.resources.DLL
PnP3dCustomControlLibrary.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnP3dCustomControlLibrary.resources.DLL
PnPIsoCore.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/PLNT3D/en-US/PnPIsoCore.resources.DLL
PnPCommonMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/PnPCommonMgd.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Message 13 of 15
aparkerUF3K8
I get the same error.  Everything is default but I can't change it.  Anybody come up with a solution?
Message 14 of 15
JameseeT3KVM
I just had this happen. I was modifying / customizing the iso continuations. I opened the iso.atr file add the isoconfig files to make a change. I also opened the clientconfig.isf to see if the change had taken place in that file.
After that I received the Unhandled Exception error message.  I pulled up a saved isoconfig file and a atr file from a few days ago. I replaced them and all seems to be working now.
Luckily I did not do to much customization before this happened.  Hope this helps guy and gals.
Message 15 of 15
juniorUZ5KS
I'm experiencing the same problem. has anyone found an acceptable solution?? really frustrating project deadlines are compromised as a result of the error. would like to add that the isometric still runs without issues
