AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Unable to Move Plant3D Files to New Location Without Losing All History
1 REPLY 1
535 Views, 1 Reply
Please tell me that I'm mistaken, but if I understand it correctly, with Plant3d and Vault, if we want to move a Plant 3d drawing into a new folder, or rename the folder, etc, this is impossible to do without losing ALL PAST HISTORICAL VERSIONS of said file?  Really hoping I'm missing something somewhere.
Here's where I got that impression: https://knowledge.autodesk.com/support/autocad-plant-3d/getting-started/caas/simplecontent/content/p...
1 REPLY 1
Just confirmed with our VAR that this is the expected workflow!! Smiley MadSmiley Mad
So that it is clear, if you are using Plant3D and Vault and you or your clients must never change their mind regarding the naming convention of your Plant3D folders, because if you change the folder names or move files between folders "YOU WILL LOSE ALL OF YOUR FILE REVISION HISTORY" if you follow the expected Autodesk workflow!  Even more exciting, if you do not follow the workflow, you will be faced with the corruption of your Vault or Plant3d or both.
Vault was pitched to us as the tool that would solve the issue of having folders of historical versions of files (70%, 90%, FINAL submittals, etc) but instead, use the built-in revisioning of Vault to store all of these important revisions.  This all works somewhat well and fine, until real life steps in and any sort of change in name occurs to your folder structure.
