Unable to dimension to custom part on isometric
sedmiston63A3G
Observer
Observer
sedmiston63A3G
Observer
Observer
I have created an end prep of FFNG for my custom part of Expansion Joint. I have created the expansion joint using an AutoCAD block along with plant part convert and added it to my catalog then placed this custom part within the Valve section. This places fine in the model and iso BOM is fine. The problem is I am unable to get this part dimensioned on the iso body. The system skips over it like it does not exist. Please see attachment for better clarification. Would like the dimension to look just like the valve on the attachment.
h_eger
@sedmiston63A3G ,
can you please upload the PCF file of your iso?
Please change the .pcf extension to .txt otherwise you will not be able to upload the file
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Degonbellz
Check your End Type...usually 4" Expansion Joint is "FL" Flanged type
Michiel.Valcke
What Iso Type are you using?
In general whether an item type is dimensioned is first determined by the theme, then under the specific dimension settings you can determine for different item types by theme how you wish to dimension them. See the reducer example below.
These settings can also be found in the isoconfig.xml. If your item type is not in the list by default you will not be able to dimension it unless you add the necessary parts to the isoconfig.xml (technically you can do it with the add button, but I still do it the old way by modifying the isoconfig.xml directly)
You'll find the necessary code (Anchorpoint) under the Themes node. it uses a filter definition to determine which items are subject to this configuration. You will also want to repeat the anchorpoint for each dimensiontype but with the 'enabled=false' setting.
Offcourse you'll also have to create a filter referring to your object type so the anchorpoint is referring to the correct objects.
MichielValcke_0-1719779086209.pngMichielValcke_1-1719779095947.pngMichielValcke_2-1719779104466.png
